One of my motors is playing up and not sure why I thought Id fixed it by swopping for another but no. So thought it might be the ESC so re flashed the firmware which didn’t help but nearly cost me a finger and severely bruised my leg ( Thank god I was wearing jeans otherwise it would of been a trip to A&E for me)
Still have the same problem with the motor were it sometimes stutters and looks like its spinning the wrong way round when fired up. But I now have an issue when I arm the quad its almost seems at full throttle, you only have to feather the stick and it off at full speed which it did at me…
Up to now iv changed the motor :- defo not that
Re-flashed the software back to the old BF then onto an older version of 4.3 :- still no luck
Checked the ESC nothing obvious :- thank god
Checked the props are all spinning same direction :- does it make a difference if your props in or props out ?? Im in …
And finally iv checked the motors are in the right order so this is where im at and a little stuck as where to go from here ???.
Oh yah and was wondering if it would make a difference if I turn my Bidirectional Dshot off ??..
Have you swapped the esc? Stuttering could be one of the 3 wires bad or a faulty mosfet on the esc
Lucky your little buddy is ok then!
Is it just one motor thats stuttering or all the motors?
Have you told betaflight that youre running props in?
Is the fc orientation correct?
Is the harness between the fc and esc wired correctly?
Just 1 motor and yah iv just followed BF as it comes up on the screen its props in so thats what iv gone with…
Yah FC is right way round Its the Nazgul I was flying at the big meet, I did crash and break an arm but repaired it ok.
But have you checked its the right way round according to Betaflight? Ive seen issues recently where people have flashed Betaflight 4.3 and for some reason in Betaflight the fc is orientated at 90 degrees. When you flashed Betaflight did you run a backup and restore it after flashing?
As Karl has said the stuttering motor is probably your esc (damaged when you crashed). Check the esc as per Bardwells video
Not 100% were Id find that info other than this ???
What you need to do is check the quad orientation in the setup tab. Check that when you move the quad the quad on the screen moves with it
Around 11.5 minutes in
It does but I think your on to something here as Iv plugged my Apex in and it states
CW is on 0 not sure what CW is but Ill alter and have another go
It depends on the fc, the settings wont necessarily be the same on each quad. The setting refers to the orientation of the gyro chip on the board rather than the orientation of the board itself. Watch the video first before you make adjustments
Cheers Steve you were spot on I needed to reset the below never would of thought of that as the quad was right in set up tab
As for the motor I will see how it goes I have a new stack coming next week due a faulty FC I purchased. It was more cost affective to buy a stack then just swop out the FC, so Ill have a spare ESC…
Funny how these things work out
Thanks again Buddy
Thats strange as that should only reset the position/orientation of the quad animation on the screen but if its working happy days lol
I dont no mate, I reset the gyro back from 0 to 180 and clicked that and it seemed to do the trick
Mind you after my close shave ( Like literally ) it might be leading me into a false sense of security
I checked my mini whoop which also has problems and noticed that 1 reads 270 on the gyro, not even sure how that works
back to the video for that 1 me thinks…
