Where can I buy DJI Mini 4K batteries?
Hi everyone,
I’m looking for recommendations on where to buy additional batteries for my DJI Mini 4K Pro. It only came with one battery, and I’d like to pick up two more. I’d also appreciate suggestions for a dedicated charger—ideally something similar to the 4-port hub I bought for my DJI Air 2S (which I stopped using due to restrictions).
Are there multiport charging hubs available for the Mini 4K Pro as well?
Thanks in advance for your help!
from what the DJI website says the Mini 2 / 2SE and SE all share the same battery as the 4k does so you should be able to get them from DJI / Amazon / Argos
There is also a charging hub like the one you get with the flymore combo or 3rd party ones via all on Amazon too.
Here is two batteries and a charging hub on Amazon
Dji store has both batteries &charging hub in stock, they are the same as the mini 2/2se.
I’ve purchased stuff from the DJI Hasselblad store in London online and received stuff the next day. Great service!!
@Rapid our Silver Members and Gold Members are eligible for a member-discount at Drone Safe Store:
Just a warning that DJI pushed a firmware update not that long ago that stops you from using non-genuine DJI Batteries
The drone will not fly
:person_facepalming: didn’t know that one - bummer !
The smart battery that is just way too smart for its own good - started with the humble printer ( HP did played that game too ) now its drone batteries - ugh !
Buying one from DJI will ensure you’ve got the genuine article. It simply isn’t worth messing about. If a battery fails, that could spell disaster for the drone. I’ve literally just taken receipt of a new battery from DJI. It was the cheapest I’ve seen and it’s spot on. It took 3 days to arrive, sadly not in time for my short trip up to North Wales, but that’s fine. There are also DJI charging cradles to fit three batteries available for about £40. USBc charging is superfast. It takes about an hour to charge 3 batteries.
Not only that they’re cheaper on dji store £139.
