Which DJI FPV replacement motor cable length?
My esteemed fellow members, may I pick your brains???
I must replace the front right motor on my DJI FPV and on replacebase there are 2 options: One with a long cable and one with a short cable.
Anyone know which I should buy?
PS PLEEEASE don’t suggest the long one and cut it down if need be. Edwards Scissorhands here is guaranteed to …
Have a look here @mpaull
You might be able to see the different cables and which corner the motor came from.
Thank you!
There are bound to be some YT “how to” vids - probably can find one that says which goes where.
I think that the front motors would have the long wires and the rear motors the short wires, as the ESC module is towards the rear of the drone.
Thanks. Pingspike pointed me to a how to vid but I’ll have to wait until the children are in bed before watching:-)
I was just thinking a teardown is less likely to mention cable length than a “how to repair” vid - although may show it.
It wasn’t a +18 cert video :thinking:
I don’t think you can get them wrong as they are sided L and R also Front and Rear
This web sites says the fronts are long the rears are short
The arms are - not the motors …
Matches @Nidge’s analysis.
