The only differences between them is v2 has larger motors and different prop mounts, A larger gimbal mount to accommodate the X5 , Taller legs again to accommodate the X5.
Hope this helps
The Inspire 1 v2 has more powerful motors than the v1. It also comes with the X5 gimbal plate by default (it’s an optional extra for he v1).
The motor / ESC upgrade was apparently to provide it with more lift, for the X5 camera. But if that’s the case, why do DJI sell upgrade kits to allow the v1 to carry the X5
Motor power goes from 350Kv on the v1 to 420Kv on the v2. But the increase in vertical lift power is at the expense of both max speed and flight time. The v2 is slower than the v1.
If you want to run an X5 on it though you’ll need to fit the leg extension kit, otherwise the X5 will touch the floor. Quite why DJI went to the time/effort/expense of fitting the X5 plate and not the taller landing gear at a cost of about £2 is anyone’s guess
I’ve not seen a thermal camera in the flesh but I’m going to guess it’s the size of the X5, rather than the X3?
£6k on a camera? I’d recommend 1) Insurance and 2) Attach the camera to the drone with a wire cable too, if you crash you’ll not want the camera going one direction and the drone going the other
Check the weight of that camera Glenn, but I’d say you’ll be better off with a v2 for the additional lift - as I guess you’re not too fussed about forward speed in this use case?
An XT 1 640 30hz thermal sensor is 12k new!!! So 6k for a slightly used one, from a friend of a senior guy in DJI seemed good to me!
I can either buy inspire from the guy ($1500, 2x batteries, 1x controller, x3 and case) OR i can just take camera and pick up an inspire in UK. Question is what can i get for the money!?
I can’t remember where I read it, I I had heard that DJI are going to be withdrawing ‘support’ for the inspire 1
This effects the price of used ones. As we can see. Might be worth checking with DJI before parting with hard earned.
I think you guys are right! I’ll sit tight for a while. There’s a Mavic 2 enterprise thermal waiting in the wings too! Odd they never made inspire 2 thermal capable! You can only run the new XT2 thermal on a matrice 200 upwards! Very strange!
Hobbymounts are foocking fantastic. I rate them very highly. They were advertising the demo bird they had for the drone show which has only got about 10 mins flight time on it.
