Flying in gusty conditions, my OSD seemed to freeze and I hit RTH (thinking it was just the OSD feed) - It was not! the FC gyro seemed to be stuck on a 90 degree angle.
I lost video feed just as I entered the trees and a good dose of throttle and blind luck pulled me out in time!
Assuming you initiated the right hand roll I’m thinking of two possible causes.
You experienced a momentary servo stall.
You experienced a momentary failsafe.
I’ve yet to have a play with an iNav system but I understand it shares many similarities to the Pixhawk/APM/Cube. If it has a similar logging capability to these systems any issues should be recorded, including loss of signal or a drop in the 5Volt supply caused by a stalled servo, which could also result in a brownout and cause a failsafe trigger.
It was me that hit the RTH switch as a test to see if the FC responded as the OSD display was frozen.
What I didn’t allow for was the FC had frozen thinking it was banked over so when I hit RTH it banked over twice as far and went into the death plummet. I had perfect RSSI the whole time though which how I punched out. I think the loss of video is because I was using a high gain helical on my monitor and it just lost signal below the tree line.
My next project is to get the Mavlink telemetry through the S-Port on the R9M so I can ditch the bulky 3DR tx.
I’m also awaiting some 18650’s to make a 3S 6,000Mah pack for longer flights.
