So why I wonder, did it suddenly do this after 112 flights of over 11 hours and near 30km?
One moment I was filming an overhead/top down shot, landed, and then took off again from a different position nearby and it then said WA, and not only that the footage was soft as well for the next 2 or 3 minutes, before I packed up for home.
Yes, but i won the drone in a competition from MPB so it wasnt a new one (as far as I know) so when i asked DJI they wouldn’t answer when i asked about putting Refresh on it.
Or do you mean the filter - cos that’s a K&F Concept one…
I actually have the wide angle and anamorphic from freewell for it along with NDs to fit on the front . That does bring up the message wide angle fitted as has some metal contacts I think to tell it
The screen message appeared between two TOAL points 50 yards apart, on opposite side of the small Japanese gardens. I landed on the path at the top of the hill, powered down both the drone and controller, then I walked down the slope to the gate into the gardens. Once there, I powered up both and the message was there…
Baffled I am… lol…
I will monitor things, thanks guys for all your input.
This is what the notification said, except all that happened was that I had landed a short distance away on the last TOAL before this info. In all this time the ND filter was on (from initial flight to last flight).
On my air 2 it’s an option. It’s in the same place as changing the resolution. One of the| options is a wide view. I’m not sure if the mini 3 is the same or not.
