Will these Mini 3 Pro parts fit a Mini 4 Pro
Hi Folks. I just wondered if any of these DJI Mini 3 Pro parts will fit the Mini 4 Pro…
  1. Wide angle lens.
  2. DJI ND filter set.
  3. Propellor holder.
    I believe the propellers and intelligent flight batteries are compatible with both models.
    Thanks … Rod
@The-Hive rod some of this has all ready been discussed mate, it pays to check first as most of the time it’s all ready been discussed on here or if not, have a browse on the internet first as you may find something of value you can post here to help others as well as yourself,
The Mini 3 Pro ND filters are not compatible with the Mini 4 Pro drone .
Yes, you can use the DJI Mini 3 Series Intelligent Flight Battery with the DJI Mini 4 Pro drone . However, please note that when using the DJI Mini 3 Series Intelligent Flight Battery, DJI Mini 4 Pro’s propulsion performance and flight time will be reduced.
Can’t say for certain about the props / holder, internet is a bit conflicting, some say yes some say no but others on here may know better, :+1:
I have just bought a mini 4 pro and on looking at accessories it seems the ND filter and wide angle lens from the 3 DO NOT fit the 4. I hope this helps.
@PitchFader Thanks Richard, I know the internet is great at conflicting different stories about things. I was unsure about batteries as on the DJI webstore they were as for both, but not any more. Tanks for your help.
@flybynight Thank you Geoffrey
You are fine with the same props for Mini 3, 3 Pro & 4 Pro, but just the prop screws are different on the Mini 3:
@bannerman100
https://store.dji.com/uk/product/dji-mini-3-pro-propellers?vid=114351
Thanks Frank, I have heard mixed things on this on the web but from the DJI store they seem to be the same for both drones including the screws :face_with_diagonal_mouth:
Cheers … Rod
@bannerman100 ahh I see here, The props and screws will fit both drones as I was asking about mini 3 pro and mini 4 pro not the mini 3.
Thanks … Rod
