3.5" Freestyle First Self-Build Advice
Evening, All!
I’m hoping to dive into my first self-build freestyle quad soon (not before some essential soldering practice!).
I’ve been looking at doing a 3.5” build with the aim of keeping it under 250g, if possible, with a 4S 850mAh battery (as I have a few and want to avoid buying more).
After some research and compiling the shopping list below, it seems this might not be entirely possible, but I’d love to hear any thoughts, advice, or tips:
Frame: AOS 3.5 V5 (68g - not sure if this includes the TPU parts)
Flight Controller+ESC: Either iFlight Beast F7 V2 55A AIO (9.2g) or GEPRC F722 AIO V2 (8.8g)
Receiver: Radiomaster RP1 ELRS Rx (2.2g including antenna)
Motors: iFlight Xing2 Unibell 1404 either 3000kV or 3800kV (total 36.4g including wire)
Props: EMAX AVAN Scimitar 3.5x2.8x3 (total 7.2g)
FPV System: DJI O3 Air Unit (40g including air unit, camera module, antenna, and coax cable)
Buzzer: ViFly Finder Mini Buzzer (2.7g)
The dry weight sums up to around 166g. My existing Tattu R-line 4S 850mAh batteries weigh 97g (officially 105g), bringing the theoretical take-off weight to around 263g. I need to shave off 14g!
I have so many questions but I guess my main ones are:
  1. Has anyone managed a sub-250g 3.5” FPV quad with an O3 AU system and 4S 850mAh batteries, or is it wishful thinking without compromising battery capacity?
  2. Any thoughts on my choice of parts?
  3. Choosing between 3800kV and 3000kV motors - any advice?
  4. Capacitor: Stick with the one packaged with the AIO FC+ESC, or upgrade?
Any imparting wisdom would be greatly appreciated!
Cheers, Kyri
@Yith
Sub250 you’ll sacrifice a lot, durability and flight time being the main 2.
Any reason you want to keep it sub 250? most of us FPVers prefer to fly in Open Space away from people anyways so no real need for sub 250g :+1:t2:
Sadly I think that the only way is to make a compromise somewhere. I just weighed my 3.5Inch at about 155g without battery. Mine uses a Caddx Vista (30g) as VTX and I use 720mah batteries that are 72g so 227g all in.
Adding a O3 at 40g and your 850mah batteries to mine for example = 262g so over again.
Sticking to O3 again plus the 720mah = 237g
Since the battery takes up the most proportion of the weight if you can consider going to 750mah maybe you might get it under. Alternately, strip the O3 casing to save 17g, but you’d reduce durability a fair bit.
Parts look ok, but maybe the ESC looks overpowered for 1404 motors. Mine is only 20A (see below) and capacitor if you go with that FC would be overpowered too so fine :slight_smile:
Motors on mine are 3800KV and is BetaFPV X-Knight 35 (I installed a different FC, ELRS reciever and ViFly Buzzer but otherwise stock)
Hi Kryro -
We all have opinions
250g +/- some tolerance. Dont be too hang up on exact mass.
Integrated receiver shave a few grammes off?
750mAh is good battery choice and lighter.
Looks to me like you need to drop that O3.
I don’t know DJI, but why not a Vista? It must be lighter… I use HDZero… so super-light Race and Whoop VTXes.
I doubt you’ll need as high an ESC rating as 55A with a 3.5" you may be able to shed some weight there.
Personally my 3.5" frame is a grinderino. At 65g it is just a little bit less that the AOS 3.5, maybe not enough. But my 3.5" is not below 250g. I did manage sub 250 with an Armattan Tadpole HD 3". that flew nice, before I bashed it to pieces…Oh and that ran on 3S.
Don’t forget battery straps, battery pad, etc…
Only way I converted my 3.5 to digital was hdzero to keep under 250g with an 800 or 850mah battery. The vista was too much. Tbh not sure which is heavier but I’d assume the O3 weights more than a vista, though you won’t get the onboard recording with a vista.i wouldn’t worry too much about slightly over 250g the rules going to change so that anything with a camera be classed the same (even a 30g AUW tiny whoop). Get A16 and you’ll be fine.
Oscar Liang
The DJI O3 Air Unit is more compact and lighter than the original DJI FPV Air Unit (39.5g vs 53.4g). However, it’s larger and heavier than the the Runcam Link / Caddx Vista (33g) and the Walksnail Avatar VTX/Cam combo (28g).
Review: DJI O3 Air Unit and DJI Goggles 2 | How to Setup and Best Settings - Oscar Liang.
6g… I’d take the O3 over the vista then and find 6g somewhere else
You make a fair point. I do have a GEPRC Mark 5 already. Despite the luxury of flying under A16, I still struggle to find enough open space to fly it comfortably. I figure a sub-250 could help increase my flying opportunities, and it might be a fun alternative to the big, noisy 5"!
How about a whoop or a toothpick?
I’ve got 2 toothpicks and a whoop. Although I don’t fly them much any more because they are analogue.
I think a 3.5" is gunna be a struggle to keep below 250g not impossible but like stated above you’ll sacrifice durability and flight time to achieve it.
Thanks for the useful tips. You’re certainly right about the compromise somewhere and probably the battery mAh is the safest and most meaningful way to do this.
I’ll check out some lower rated ESCs as there does appear to be around a 2g weight saving here. If I can find lighter options for other parts as well, even a gram each then I might just be able to chip away at it and hit the <250g target.
Possibly. I’ma head back to the drawing board and have a think. Cheers Deano :slight_smile:
Haha! Funny because it’s true :wink:
It shaves off about 1.8g…every little helps!
I did consider this but don’t want to lose the on-board recording.
I was debating the grinderino alongside the AOS 3.5 V5. I saw a couple of your flight videos with it as well…your build flyyyyys!!
Of course I forgot these :sweat_smile: Thanks for the reminder!
Thanks for all the tips and info, guys. Defo some food for thought.
I’ll post some pictures and videos here if/when I get around to buying and building it!
For what it’s worth, I also have a 5" and can fly under A16 - but as a suburbia-dweller, sub-250g is basically what makes it practical for me to stay in the hobby. If I’d relied on flying full-fat 5" to learn to fly I’d still be on the ground!
So if you feel like being tied to 5" means you’re struggling to fly as often as you want, I’d say sub-250 is absolutely worth a go.
At the moment I turn up to my local park with a sub-250 5", a “traditional” 3", a 3S toothpick, and an Odonata. And I fly whatever seems considerate to the other park users on that particular day!
You hit the nail right on the head!
A couple of very noob questions…
Am I correct in saying with either of the following AIO FCs I would need to solder the input of the DJI O3 Air Unit directly to a Vbat pad or (if there isn’t one) to the (+) XT30/XT60 pad on the board to power it?
  • Flywoo GOKU GN 405S 40A AIO (MPU6000)
  • Flywoo GOKU GN 745 40A AIO BL_32 V1.2 (MPU6000)
Whereas on the following boards, the 6 pin connector for plugging in the Air Unit would pass through Vbat and should provide enough power without soldering a wire elsewhere?
  • GEPRC GEP-F722-45A AIO V2
  • iFlight Beast F7 V2 55A AIO
  • BetaFPV F722 35A AIO V2 BLHeli_32
Just for info, this is my 4" Chimera 4
With a 550mah battery it just sneaks in under 250g. 650 or larger takes it over 250g
That is with Caddx Vista, using the integrated receiver, and a Succex-E Mini F4 35A FC. Xing 1404 3800 motors. It also has a BN-220 GPS module fitted.
I previously had a DJI Air unit in this drone, and even with a 450mah battery it was still 258g.
I don’t think you can power O3 from Vbat
Should 9v or 12v pad or from a separate uBEC
:thinking: @GunjaFPV @DeanoG60 :thinking:
