Air 2 Props not getting up to speed from hand launch
Was out today and sent the Air2 up, flew until I had the first battery warning and brought her down. Changed the battery and went to hand launch, the props only spun up to maybe 30% and the gimble went all wonkey. I was in a wooded area so decided to walk out of it in case there was a gps problem. The drone went mental and the props spun up to speed, but I couldn’t let go as I was still under branches. Once I got out onto the road I let go of it and it flew back in towards the trees!!! Fortunately it stopped, possibly the collision sensors kicking in? The gimble was stuck at a funny angle so I powered down, walked out to a clear space and took off again, all sweet for the rest of the flight, very strange indeed!!!
Any ideas on this one? I’ll get the airdata posted up shortly for you to have a look at.
Youve not been fing about with the parameters again :joy:
homing bird… it was happy in the woods, till you took it out so it wanted to go back :laughing: (not the foggist idea!)
Not this time mate, was really, really strange indeed
Forgot to post this if anyone is interested? Can post a link later if wanted/needed.
The heights and distances are absolute garbage by the way, it never moved more than ten feet, despite what the gps says
I would reset the drone and reflash the firmware
I’ll give that a try, thanks. Thing is, once I shut it down and restarted, it was perfect??? I’ll do the above anyway, wont do any harm and at least I’ll be sure it’s not a software/firmware fault. Starting to wonder if something internally got damaged after the last “incident”
