Gham
30 August 2022 21:24
21
@PingSpike so the android revolution has started. What device is taking your fancy?
You can leave the drone on the ground but the rotors definitely need to be spinning for the remote id to be broadcasting.
If you start the rotors the display in the Fly app will change to āin flightā, even though itās still on the ground. Thatās enough to get your beacon emitting
Iāll split this thread out later, weāve got two clearly different things going on in here.
I donāt fully understand how or why as Iāve not researched it enough, but itās a safe bet this will be why your Mini 2 isnāt showing up @SparkyFPV
# Transmitter Devices
This page provides a list of transmitter devices that are capable of broadcasting Direct Remote ID signals according to the ASD-STAN prEN4709-02 (EU version) and ASTM F3411 (US version) standards.
For more information about Remote ID and links to additional resources, please see the [opendroneid-core-c project](https://github.com/opendroneid/opendroneid-core-c#opendroneid-core-c).
A [list of smart phones](supported-smartphones.md) that have been tested to receive Remote ID signals is available and information about various open source receiver implementations is available [here](https://github.com/opendroneid/opendroneid-core-c#receiver-examples).
This list is work in progress and can contain wrong or misleading data.
If you want any data added, removed, corrected etc., please raise an issue or provide a pull request with the changes.
The intention of this page is not to promote or exclude any specific commercial or non-commercial devices or implementations.
It is merely meant as a helpful source of information for people interested in Remote ID.
If you have information about devices not on the list, input and updates are very welcome.
The list is divided into three sections: drones, add-on devices and other implementations.
## Drones
The rules in the US and EU are not yet mandating that drones must broadcast Remote ID signals.
This file has been truncated. show original
tl;dr version:
No Mini 2
Are we getting the Drone Id and DJI Aeroscope mixed up?
DJI AeroScope:
How does it work?
DJI AeroScope is endorsed by the UKās Centre for the Protection of National Infrastructure.
It is a passive radio frequency (RF) system that tracks real-time telemetry data from all DJI drones (around 80% of the market) within its range.
Generate detailed flight logs, including statistical reports and heat maps, for analysis.
Entirely possible these days man
So @speatuk could test it out on his Mini 3 and the Mavic 3
DazC
8 September 2022 09:40
27
OpenDroneID is not picking up the drone while in flight? I downloaded and installed from the above link, must be missing something. Time for some more reading. And no I havenāt applied the hack yet
It does not work, the DJIās donāt use Droneid what they use is Aeroscope and that is what you are disabling when apply the exploit
The drone Iād app does work, but not with the Mini 2.
The Mini 3 and Mavic 3 work, thereās a link knocking about somewhere.
They only use WiFi Beacon and some phones donāt have that, and we donāt know the range of detection using a phone
Also, the older DJIs and the newer Miniās 1 and 2 use Aeroscope but we donāt know the difference between the 2 and if the exploit ciajeepdoors disables both
On my Mini 2, it says it disabled Droneid but you have posted above that it doesnāt have Droneid but it can be tracked with Aeroscope from what I can gather
Found this but not tried it yet
āThis app is a tool to educate both drone pilots and others about the upcoming FAA requirements around Remote ID. This app will simulate locating drones in the area and show them on the map.
Starting with version 1.4, the app, when running in Law...
says it only a simulation
If youāre coming on Sunday Wayne Iāll bring my drone id phone along
I bought a busted up Huawei Mate 20 Pro from eBay in the end as this model seems to have the best detection/radio/comms support.
chrisf
15 September 2022 07:58
35
Is it worthwhile breaking the DroneID app into a separate thread where people can post which phones theyve tested on?
Iāve tried it on 5 phones with no luck on any
Yes, agreed, will sort later today.
This PoC app from DJI back in November 2019 is / was also related:
Some kind of remote drone ID app for Joe bloggs, is it a concern?
If you can add to the list of devices that have the correct hardware and are compatible with the app then please contribute here .
A list of devices that are not compatible isnāt of much use (as itāll be a mammoth list)
## Introduction
This document contains a list of compatible smartphones that have been tested for receiving the Broadcast Remote ID signals from an Unmanned Aircraft (UA) or add-on device following the European and US standards.
It is part of the documentation for the example Android Remote ID receiver application available [here](https://github.com/opendroneid/receiver-android).
General information about Remote ID can be found [here](https://github.com/opendroneid/opendroneid-core-c#opendroneid-core-c) and a list of Remote ID transmitter devices [here](transmitter-devices.md).
The current specification of both the ASD-STAN prEN4709-02 (EU version) and the ASTM F3411-19 (US version) standards rely on wireless protocols in the unlicensed spectrum to broadcast the desired identification and telemetry data from UAs to ground observers.
Particularly, they define transport methods over Bluetooth 4 Legacy Advertising, Bluetooth 5 Long Range (Advertising Extensions over Coded PHY S8), Wi-Fi Beacon and Wi-Fi Neighbor Awareness Network (NAN).
The main reason for choosing these wireless technologies is that they meet the requirement of being supported on ordinary mobile devices.
Neither of the above standards cover the receiver side of the Broadcast Remote ID.
This document provides a quick overview of the compatibility of community tested smartphones with the specified Broadcast Remote ID technologies.
The current stage of the prEN4709-02 (per January 2021) is a finished draft at CEN Enquiry, and the final version will be published in the upcoming months.
To obtain a copy of the ASTM Remote ID standard, please visit this [link](https://www.astm.org/Standards/F3411.htm).
**Disclaimer:** The list of tested devices is not exhaustive and comes without any guarantees.
It might contain some errors and misleading information.
The only devices that seem to receive all of the beacon data are
chrisf
15 September 2022 14:20
40
Well, none of the devices i have access to work.
Xiaomi Mi11
Google Pixel 5
Samsung Galaxy A12
Huawei Honor 9
Oppo Reno Zoom
This is despite at least a couple of devices showing all 4 of the requirements in the OpenDroneID app shown as supported.
