I crashed my Mini 2 it survived, my Mini 3 Pro has had two and survived full belt into an oak tree, back out and flying the day after with just two props which needed replacing, it flew ok but just to be safe I replaced as small nicks in them
My Mini 2 survived a few scraps, but the Mini 3 Pro didn’t survive it’s first brush with a tree. It was the fall and landing that broke the gimbal. I guess it just depends where they hit and how they land.
I saw a mini 3 dropped from hand level (the guy was trying to hand land), dropped and broke gimbal, so wasn’t high. All a bit of luck if you hit a tree and drop down short distances, could be fine, depends on angles, speeds, etc, etc. They are pretty solid, though not as solid as an avata or a carbon FPV drone.
DJI FPV is fragile though
Yep, my M3P accidentally hit a railing about 4ft high and headed straight downward at warp factor 7 into a paving slab. Broke the gimbal ( repaired by Heliguy )
