Avata 2 flying backwards
No PC needed just your phone and your goggles
@milkmanchris do you mean a recorded view view from the goggles with the hud? ive only been recording from the drone camera no heads up display. OR do you mean the djy fly app data? is that downloadable? ill have a look now.
@RemoteIDsaveslives ill take a look at airdata. im on the computer now just revising for A2CoC.
im not on my usual computer you see and dotn actually have all the cables i need sufficiently. To up load those videos to YouTube i had to download the files to my phone then upload them to google drive to then download on the computer ive currently got access to. just to be able to upload to youtube. cant connect my phone to this computer. bit of a bollock ache tbh :face_with_hand_over_mouth: will i be able to set up the airdata account? how do i get the info from drone?
The goggle SD card video (it would record any warnings)
Airdata account can be set up from your phone/tablet or any browser nothing is held locally
ive been putting my sd card in the avata
You will need to connect the goggles to a phone with the fly app on and sync the flights to DJI
Then in air data sync to your dji account and it will pull them from the DJI server
just syncying from the fly app to dji now
ive synced the flight logs and set up the airdata account. for some reason the flights i posted on youtube arent in the data. does it log the total time for a seperate log for each flight? how do i share it on the forum? from the preview it doesnt look like those flights i posted on youtube.
there are loads a warnings and says when ive gone into manual mode its repeated many times
On the flight page use the share option and post the link here
two from today this morning. the two most recent
is there a ‘run through’ or play button on airdata?. im trying to find the flights from those exact video i posted on youtube but becuase i edited the video down i cant quite tell from the yellow flight illustration
has the manual mode button been accidently mapped to the gimbal angle selector button maybe. the dial is what i ment but i dont think thats it
I think this is your fault, this is when it is flying backwards and you have the right stick slightly down which will tilt the pitch back causing the drone to fly backwards
Also, you never push the right stick forward so the drone will continue going backwards
ok ill have to take it out and have a play. ive been flying the same way for a couple weeks and not noticed anything like this before. is the pitch it that position enough to make it fly backwards at that speed? the thrust is also down so the power is too?
mayabe its just getting used to it and a bit of a learning curve
Yes it is in manual and the speed wasn’t fast but it will get faster till you change the pitch
Also with the camera gimbal this will affect how you fly, more angle means the drone needs more forward pitch (faster it will go) or you are looking up at the sky
am i making it harder to learn/fly then by having the camera angle around 15 degrees?
thanks for all the help. im off to go take it out :flying_saucer:
