No but the faster you the more angle you will need and the slower the less
Ive taken the lassi out a couple of times yesterday and its not flying backwards anymore. Its sill doesnt âfeelâ right but im putting it down to lack of experience. The rates have been changed back to normal and so roll and yaw plus general hamdling does feel different. Just wanted to say thanks for helping @Onanist @milkmanchris @GunjaFPV @RemoteIDsaveslives
Figured out what was up with the avata âflying backwardsâ i wss setting the camera angle to minus 15 degrees so it felt all soft and floaty. It should be above zero degreeâs. The faster tyou fly the higher the angle you need as the drone is tilting forwards more. Just thought id let people know if they come across the same issue. Thanks again
Lol yup thatâd do it. Great you can just use the little tilt thing dial or switch on the avatas and DJI FPV to change during flight. Such a different experience to the ones Iâm used to. Servo wouldnât be hard to setup I guess⌠Hmmm
