Rich, Bitdefender, clicked your link and there it was, turn off, so i did ![]()
Brilliant, thanks Mick.
Glad youāre up and running again, Drone Scene is sooooo much better when you can see what youāre looking at ![]()
A bit like Sundays meet, me looking round where the fuck is that drone.
Then 2 voices, Mick itās above your head ffs ![]()
The Voices 1 was paul the other @milkmanchris Chris ![]()
Sorry Dave, just re read the topic and forgot to answer you, erm works fine on phone
No probs.
When I go into DroneScene on my PC all the map data is missing. All the areas to fly in are there but no map just a plain yellow background. Any advice on what might be wrong.
Gordon Gilfether
Hello @Gogs1
āItās working hereā isnāt what you want to hear ![]()
Soooo, what might be wrong? ![]()
First up, can you try using a smartphone or tablet or another computer please? Does it work on another device?
If so, back to the faulty PC, try using a different browser, does the work?
If so, we know itās your āmainā browser thatās at fault. Try disabling any browser extensions / plugins / add ons.
Someone reported something that wasnāt compatible a while ago, Iāll see if I can find the thread again.
Turns out it was BitDefender that was causing someone issues in the past @Gogs1
Details are here: Base map tiles not loading (Bitdefender was the cause)
Are you also using BitDefender?
That will have been me then ![]()
But the group came together and bosh
Sorted ![]()
Hello PingSpike.
Partially solved the problem. Downloaded the web browser Brave and the DroneScene maps working fine. Problem was either to do with Microsoft Edge or Bitdefender (or both). Tried clearing the cache on both but didnāt seem to help. But working well on Brave so I am quite happy.
Gogs
BitDefender strikes again ![]()
Glad youāre sorted @Gogs1 - thanks for letting us know ![]()
Thanks for the info regarding Bitdefender, have had the same problem of no map detail but turned off the tracker extension and now all good.
Many thanks. Brianf
Advice on drone scene map pleasā¦
why is the drone scene map not visible on my windows pc??
Can you explain what you are getting or a screen shot Charlie @Indy-Garden as it works fine on my PC.
Without knowing or seeing anything Charlie, at a guess, youāve got Bitdefender installed? ![]()
Iām not familiar with Bitdefender so maybe someone else can help here, but check to see if there are any notifications around Bitdefender blocking api.mapbox.com (which is the map-tile provider)
If so, can you tell it to trust or accept mapbox somehow?
Iām also guessing it works ok on your phone?
(so we can rule out a broadband issue)
As per Andy @Onanist 's post, please do share more details so we can fix you ![]()
~Many thanks for the suggestionsā¦
it works on me phone and I use bit defender on both pc. was that a lucky guess??
. If i can work out what you are talking about i give it a goā¦
if that dont work i will post a pictureā¦
It was an educated guess, Charlie ![]()
Try disabling or turning off Bitdefender to confirm thatās the cause of your issues.
Thankyou ⦠Pausing Bitdefender made no diference⦠but preventing start up on boot ⦠and rebooting Drone scene be working fine⦠![]()
have turned Bitdefender back on⦠now i know were the problem is⦠even if i cant fix it.
thanks again
Charlie @Indy-Garden this worked for some people in the past:
What I think you might see when you get to https://api.mapbox.com is a warning from Bitdefender? ![]()
If so, tell it to accept / safe / whitelist / something for api.mapbox.com
Sorry I donāt have a Windows PC or Bitdefender so I canāt help much more than this ![]()
