Thank you for your help.
Adding an exception to bitdefender did not work nor did any changes to settings etc.
However, Changing to browser settings on edge to turn off anti tracker allows Drone scene to function ok.
Im not sure of the implications of stopping anti tracker.
i guess the there option would be to change Bitdefener for something else… not sure what would be best course of action,
Charlie
Just use Windows’s own security centre it is as good as any other and its free
sound like the best option… and a like the price.
Hi,
I now have the problem of no background maps since installing Bitdefender.
I wanted to open Dronesene in Edge and found it works fine in “inPrivate” mode.
My solution was to create a shortcut with this in “the location of the item” :-
“C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe” -inprivate -new-window https://dronescene.co.uk/
It works for me and is easy to do and easy to make links to the shortcut.
P
Does Bitdefender have no way of whitelisting or trusting or excluding or adding something for mapbox.com so the base map tiles load?
