Possibly how do you get it to say mph btw?
Set it in betaflight under the GPS tab if I recall correctly. Might be in the configuration tab change it from metric to imperial.
I’m Defford going 6s next year. Top job Howard
Thanks mate. 6s defo the way forward.
Gonna acquire some higher power 6s and see if I can squeeze a little more out
You’re gonna need some younger spotters too
Tut……!
Speak for oneself.
So as well as this entry for the Nazgul 5 v2 which seems to work out at 150.9 mph.
I’d also like to throw this one in the mix for my Chimera 4 Lr at 75kmh or 46.6mph picture below
Charge your 6s on hv mode. It stands for high velocity
Also ordered at 1300 mah 6s. I’m only on 1100 mah 6s right now
And is this one taking the current # 1 slot away from @notveryprettyboy ?
I can’t verify any FPV stuff so I’ll look to you all, the FPV flyers, to say yay or nay on the 150.9MPH screen shot there?
No worries. Both are built by Iflight and are bnf.
The first is a Nazgul 5 v2, the latter slower is a Chimera 4 lr.
bnf?
Is that the same as RTF?
Nazgul is the quick one
Chimera 4 lr
Both BNF - bind and fly drones. Just add a transmitter and goggles.
bind and fly - so they have rx fitted you just need a tx and goggles.
Just means I dont have to do any soldering just set them up and fly.
I was there. I can verify this happened and these were the speeds recorded.
I’d say it looks good . Definitely with the 6s he ran it off. Better to have a video clip in future though with speed and gps sats.
@DeanoG60 got nearly 250mph but his sats were low
Thanks everyone, I’ll update this evening
I have a video all beit from my attached camera rather than my fpv cam
I Will give it a re-run with my HV 6s when it arrives and the rain doesn’t stop the fun
