Hi I have a mini 4 pro as most people know sub 250g, i do not have the CofC (A2). But i am have a question regarding article 16. What i would like to do is put 360 degree camera on to the drone, so this would take the drone over the 250g which i would not be able to fly since i do not have the CofC, How ever if i used article 16 would this then be possible for me to fly with out having the CofC ?? Just a side not does being a member of greyarrows have article 16 included if you are a paid member? Thanks in advance,
Why not?
In a field, yes.
Anywhere else, use Good 2 Go to find your answer:
Not yet
We’re currently considering this route and may have more news to announce in the new year.
On a Mini 4 what does the camera weigh?
Hi thanks for your reply, i seen this amazing youtube video of edinburgh castle, and you can move the the angle of what you are seeing as the drone flys, and i thought i would like to try. The reason i said i could not fly my drone, i thought since i never had CofC i could only fly a drone less than 250g. Here is a link for the youtube video that has got me thinking
I’ll refer you back to Good 2 Go again:
Thanks the weight of the insta 360 is 26.5g then add a mount so looking at total including drone max 270g
What did Good 2 Go say?
Says “GOOD NEWS” thanks again,
thank you
Which Insta 360 is that? My x3 and One Rs both weigh around 200g which I reckon is pushing it on a Mini drone.
insta 360 one x2 (149g) The insta 360 i thought was 26.5g which it is but does not do 360
Good luck
i have seen videos of the mini 2 lifting over 200g, granted battery never lasted,
I feel sorry for the motors and ESC
Never mind the top heavy displacement affecting the imu caused by a camera strapped to the top
Good luck
This is the drone used in the video
I’ve used a onex2 with an original MP a M2P and the DJIFPV with ease
Not sure the Mini range is upto it , chase YouTube there’ll be something on there
