Bit of a noob question perhaps, but I can’t find an obvious answer online, so here goes.
I have an Air 2, and love it, but I’ve had an offer of a Mini 2, just the drone itself, no battery or controller. Sourcing a battery is no issue, but would I be able to use the air 2 controller with the mini? They appear to be identical but does the relationship between controller and drone have to be monogamous, or will it just latch onto whichever drone is nearby and switched on?
Thank you. I probably should have phrased it better, I’d expect to have some sort of pairing process to swap over, but hopefully that connection isn’t permanent. That’s what you get for trying to post questions and cook lunch at the same time!
Hi im thinking of adding a mini 2 to my air2 collection
Can i pair both mavics to the same controller to save carrying two controllers around or does each controller only allow one drone to be paired with it
