I’ve now received my contoller and linked this up to Velocidrone - no problems.
Next step is to link my EV800D goggles, which isn’t as straight forward. From what I can see, I need an HDMI2AV converter and a camcorder RCA to 3.5mm jack and this should then work.
Can anyone confirm if this works before I go down this route?
Yeah does say video in. though that’s composite old style yellow, how you output that from a PC… you’d need some kind of adapter, and don’t think it’ll be cheap. could be wrong.
I don’t use my EV clone (was meant to be a real EV800, but hey ho got conned), on the PC, just he radio master!
I did this with my DJI goggles V2, hdmi to rca adapter, TRRS to RCA cable, all good to go. Bit of a faff, not the greatest quality etc etc, but it works. I hope it’s a similar experience with your goggles
They’re not too bad, you could have a pretty lengthy session without any problems.
Really glad I did this, I’m not getting my drone for another 6 weeks, so practicing with the goggles should make a real difference, it’s a completely different experience to using the monitor.
Pleased with my flight progress so far after only a few days, although real life will be different I’m sure.
