Another drone vid 3D analysis and 3D text …
(Can’t recall who’s vid I borrowed - not mine.)
Creating something from absolutely nothing.
All created from a blank page in Fusion.
This is the stuff I really like doing.
Spangly! Nice lighting. I remember playing with an early version of Photoshop (I used to be a graphic designer) when they introduced 3D vector stuff trying to do 3D type (don’t remember trying to animate it though). I have trouble getting enough time just for ordinary editing, so Fusion may have to wait.
Thanks for this. Watched the shorter of the 2 videos last night and found it really useful. Great that he also provides all of the clips and other elements so you can follow along with the workflow. Everything suddenly makes a lot more sense!
Casey is one of YTs best for DR tutorial videos - his channel is definitely worth a sub
What’s New in DaVinci Resolve 19.1.1
The following features have been added or updated.
• Addressed an issue displaying track controls in the edit index.
• Addressed with an option to paste to playhead or in and out range.
• Addressed a crash previewing a transition on some clips.
• Addressed issue switching multicam angle when on an edit point.
• Addressed issue switching angle for multicams with speed changes.
• Addressed opacity or fader previews with non-black backgrounds.
• Ability to import and export Final Cut Pro v1.13 XMLs.
• Addressed multiline subtitles having incorrect line break.
• Addressed issue with rendering a SphereMap in software.
• Addressed issue with outer poly rendering on linear b-splines.
• Addressed an issue with loading from disk caches on macros.
• Addressed timeline thumbnail displays for some spatial photos.
• Addressed ColorSlice highlights preview on clips with Magic Mask.
• Addressed grades resetting to local versions in collaboration.
• Addressed incorrect tooltips when switching between DCTLs.
• Added new color thumbnail index tag for clip ordering.
• Addressed an issue when dropping out of automation trim in play.
• Addressed an issue with interpreting full clip fades in AAFs.
• Addressed a round-trip issue with Fairlight external audio process.
• Addressed dialogue leveler gain control range in the main plugin UI.
• Addressed FairlightFX reverb, noise reduction automation issues.
• Addressed an issue setting audio interface sync source to internal.
• Addressed audio accelerator issues with desktop video devices
• Addressed availability of shutter angle metadata as a tag.
• Addressed issue importing SRTX subtitles to the media pool.
• Addressed H.265 encode issues on older NVIDIA graphics cards.
• Addressed an issue with H.265 multipass renders on macOS 15.1.
• Addressed XDCAM encode option to select file or disc as target.
• Render option for Windows 10 media player compatibility for MP4.
• Addressed incorrect OpenFX slider changes with mouse scroll.
• General performance and stability improvements.
No reboot needed (for me) - Win10
Works fine here. As did 19.1.0.
I still cant get my head around the way DR interacts with the OS and colour management (or more to the point, doesnt).
Getting consistent output is hard.
Well - it obviously does, when set up correctly - because many of the top colourists in the world (MacOS and Windows) use DR.
Is it easy to fully understand? Nope - it’s not. But then again, using any other editor with full-featured pro colour management is no easier.
Is it worth researching on YT to better understand it? Definitely.
Do I fully understand colour management? Nope. The world of Colour Spaces, Gammas and Gamuts is a real minefield … but, personally, I like trying to learn this shit. #masochist
One of the biggest problems is that DR is, fundamentally, a very pro piece of kit, and many of the YTs that might otherwise help are biased, in content/terminology/technicality toward pros using kit that’s in a different league (technically, and also in colour space terms) to DJI footage. So trying to follow along with these vids can be a real
exercise.
And then, because of the power of DR, the same thing can often be achieved in half a dozen ways, and different YTs use different ways.
I try to concentrate on finding ones that are focusing on D-Log (on one of its guises) and Rec709 - depending on my limited range of devices. But then the tech beyond what I have or need fascinates me and I’m off down another rabbit hole learning stuff that’s of no direct use to me - but can help me understand the minefield a little better.
No not “obviously it does” at all.
Firstly, the app itself is NOT ICC/OS colour profile aware on windows. This is documented.
You:re supposed to create a 3D viewer LUT to apply in the project settings to allow the internal viewer to display accurate colours. This i have done but doesnt seem to work that well.
Contrast to Premier which is full ICC aware by default so doesnt need any of these workarounds.
The new v19 has a “use Windows colour management” tick box. Nobody seems to know what it does, its not in the new reference manual and doesnt SEEM to fix it. The BM forum isnt able to help of that.
Professional colourists use a declink/lutbox to an external display calibrated to sRGB and so on. They generally dont work on colour using the internal viewer and screen.
Im fully aware of colour spaces, gamma and gamut (my day job for the last 10+ years has been photography). My screens are setup, hardware calibrated and profile. The issue is Resolves handling of it.
We’re not talking about applying the right colour space to footage or anything like that here. Its what DR displays in the viewer not matching the actual colours of the calibrated display (or output) as internally it ignores the ICC profile, or at least did.
With a properly calibrated P3 display, creating a Rec709/2.4 LUT and applying that SHOULD produce consistent output as per the docs. However it doesnt. Again the BM forum only solution is “you need a declink external display”.
An hour long YT on 40+ Studio Only features.
Dear Santa
I’ve been a very good boy this year.
A frigging mega awesome laptop would be really handy.
TIA!
@OzoneVibe
UPDATE TODAY
What’s new in DaVinci Resolve 19.1.2
Update out for DaVinci Resolve Studio 19.1.3. This release is available at no charge for existing customers from their support web site.
What’s New in DaVinci Resolve 19.1.3
• Delete unused cache now correctly accounts for transitions.
• Addressed blank viewer previews for some Fusion templates.
• Addressed offset issue with imported AAF clips.
• Addressed issue enabling auto resync for an empty folder.
• Addressed issue with left clicking to patch source tracks in edit.
• Addressed issue with searching all fields in the edit index.
• Addressed issue with focus when typing in text fields.
• Addressed Fusion saver issue rendering EXRs from ARRI MXF clips.
• Addressed crash in Windows systems with old AMD CPUs.
• Addressed issue with fades and crossfades when moving clips.
• Addressed audio retime issue in 192 KHz sample rate projects.
• Addressed issue with keyframing split tone in Film Look Creator.
• Support for ARRI Alexa 265 clips.
Almost 2 months and no updates ..
.. is v.20.beta about to appear? .. or a big v.19 update, at least.
Voice activated AI editing? “Make me an awesome video from these clips.” .. sit back and watch it create an Oscar winner.
A beginners guide to DaVinci Resolve 19 is available for FREE via the Blackmagic website.
You can also buy it too via Amazon - the paperback ver is a bit pricey at £73.34 - Amazon Link might be cheaper elsewhere.
You can find the link to download here or to buy via the US Amazon site along with tutorial material and other guides too - here out -
I wish.
Not much - considering it’s been 2 months
What’s New in DaVinci Resolve 19.1.4
• Support for Blackmagic RAW SDK 4.5.
• Apple ProRes encode support on Windows and Linux.
• Support for Samsung Log LUTs.
• Addressed network decode performance for large embedded AAFs.
• Addressed issues with exporting embedded AAFs.
• Addressed audio stutters when recording interlaced media to tape.
• Addressed inspector audio track selections for source multicams.
• Addressed issues decoding some transport stream clips.
• Support for Photon 4.10.8.
• Addressed issue with importing large Dolby audio files.
• Addressed playback delay after import for large Dolby audio files.
• Addressed issue with default ISO selection for Canon RAW clips.
• Addressed centre crop issue playing back ARRI RAW clips.
