DJI Air 3 firmware updates
Date: 2023.07.25
Aircraft Firmware: v01.00.0300 ARB 0
Controller firmware:
– v01.00.05.00 (DJI RC 2)
– v01.00.03.00 (DJI RC-N2)
DJI Fly App: v1.11.0
What’s New?
  • Added support for taking 48MP photos.
  • Added support for adjusting style parameters such as sharpness and noise reduction in video mode.
  • Added support for shutter speed options of 2.5 seconds to 8 seconds for simulated long exposure when taking 12MP photos.
  • Added support for using wide-angle lens.
  • Optimized RTH in low-light environments.
Notes:
  • Camera settings will be reset after firmware update. Check the camera settings in DJI Fly.
  • If update fails, restart aircraft, remote controller, and DJI Fly or DJI Assistant 2 (Consumer Drones Series),and retry.
Date: 2023.08.28
Aircraft Firmware: v01.00.0400 ARB 0
– v01.00.06.00 (DJI RC 2)
– v01.00.04.00 (DJI RC-N2)
What’s New?
  • Fixed some known issues
Notes:
  • If update fails, restart aircraft, remote controller, and DJI Fly or DJI Assistant 2 (Consumer Drones Series), and retry.
I wish they’d tell us what these “issues” were :confused:
I wondered what the known issues where as well
Date: 2023.09.25
Aircraft Firmware: v01.00.0600 ARB 1
– v02.00.00.00 (DJI RC 2)
– v01.00.05.00 (DJI RC-N2)
DJI Fly App: v1.12.0
What’s New?
  • Added support for taking five 48MP photos when using AEB and Burst Shooting.
  • Added AR Home Point, AR Return-to-Home Route, and AR Aircraft Shadow.
  • Added support for manually setting the Max Horizontal Speed in Normal mode to 15 m/s.
  • Added support for DJI Goggles 2, DJI Goggles Integra, and DJI RC Motion 2. Visit DJI Air 3 - Downloads - DJI and refer to the Consumer Drones and Goggles Compatibility Information for more information.
Notes:
  • Make sure to update the firmware of the aircraft, goggles, and motion controller before linking. The user can use DJI Assistant 2 (Consumer Drone Series) to update the firmware of each device individually, or use the DJI Fly app to update the firmware:
    – a. Aircraft: Update the firmware with the remote controller.
    – b. Goggles and Motion Controller: Power on the goggles and the motion controller. Connect the USB-C port of the goggles to a mobile device, run DJI Fly, and select Profile > Device Management. Locate the corresponding goggles. Select Firmware Update and follow the on-screen instructions to update the firmware.
Date: 2023.11.02
Aircraft Firmware: v01.00.0700 ARB 1
Remote Controller Firmware:
–v02.00.01.00 (DJI RC 2)
–v01.00.05.00 (DJI RC-N2)
DJI Fly App iOS: v1.12.3
DJI Fly App Android: v1.12.3
What’s New
Fixed some bugs.
Notes:
Overview:
  • Date: 2023.12.21
  • Aircraft Firmware: v01.00.10.00 ARB 2
  • Remote Controller Firmware: v02.00.03.00 (DJI RC 2)
    v01.00.06.00 (DJI RC-N2)
  • DJI Fly App iOS: v1.12.4
  • DJI Fly App Android: v1.12.4
What’s New
  • Added Auto mode for ActiveShots 360°.
  • Added Vision Assist.
  • Added digital zoom for 12MP photo mode.
  • Added Vision Positioning and Obstacle Sensing switch.
  • Added Sphere Panorama for the medium tele camera.
  • Added support for civil uncrewed aircraft owners to register their aircraft with CAAC using their real names to comply with the uncrewed aircraft-related regulations in China.
  • Added support for Front Arm LED settings in the EASA member states and the UK.
  • Added support to make camera parameter settings unaffected by firmware updates. This function will only work if the aircraft firmware is v01.00.06.00 or above before an update occurs.
  • Optimized battery auto-discharge strategy.
  • Fixed some known issues.
Notes:
  • Added features require DJI Fly v1.12.4 or later.
Wow, Vision Assist, thatwas the only feature I was really wanting that made me think of the MAVIC3…
Anyone had issues since updating the Air 3 with latest firmware …
Had this ever since . I’ve redownloaded via DJI assistant 2 and still get error so contacted DJI…
Bizarre as it sounds, try hot spotting to your mobile phone and have your mobile phone use the mobile network (ie. don’t have your mobile simply relay over your home wifi).
I had this message the other day, I posted in the forum somewhere,
Try taking it outside ( not connected to WiFi ) turn everything on as is yr going to fly, only when you have full GPS lock then go into fly safe update & try to update it, fingers crossed it should get rid of it :crossed_fingers:t2:
Edit just found the post
Sorry @PingSpike did not see what you typed while I was typing, appologies.
Date: 2024.04.11
Aircraft Firmware: v01.00.1200 ARB 3
– v02.02.0000 (DJI RC 2)
– v01.00.0700 (DJI RC-N2)
DJI Fly App: v1.13.0
What’s New?
  • Added support for DJI Goggles 3 and DJI RC Motion 3. Visit DJI Air 3 - Downloads - DJI and refer to the Consumer Drones and Goggles Compatibility Information (for DJI Goggles 3) for more information.
  • Added support for Israel Remote ID requirements.
Notes:
  • Added features require DJI Fly v1.13.0 or later.
    and retry.
Updated release notes published today, for yesterday’s firmware release:
Overview
  • Date: 2024.04.23
  • Aircraft Firmware: v01.00.1300 ARB 3
  • Remote Controller Firmware: v02.02.0000 (DJI RC 2)
  • DJI Fly App iOS: v1.13.1
  • DJI Fly App Android: v1.13.1
  • What’s New
  • Notes:
New update still not fixed “P” mode issue
  • Overview
    Date: 2024.06.27
    Aircraft Firmware: v01.00.1400 ARB?
    Remote Controller Firmware: v02.02.0100 (DJI RC 2)
    DJI Fly App iOS: v1.13.8
    DJI Fly App Android: v1.13.8
  • What’s New
    Added support for Enhanced Transmission in some countries and regions.
  • Notes:
Another new Air 3 firmware was released today.
Same version as the last one, just with RC2 updates inside it :man_facepalming:t2:
Old filename: https://dl.djicdn.com/downloads/DJI_Air_3/RN/20240627-1/DJI_Air_3_Release_Notes_EN.pdf
New filename: https://dl.djicdn.com/downloads/DJI_Air_3/RN/20240627-2/DJI_Air_3_Release_Notes_EN.pdf
They are the same other than the fly app version as the iOS is still on 01.13.8
Cheers Wayne, looks like it was just the Mini 4 Pro that ships with the RC2 update to v02.02.0200 as the Air 3 included it last time.
A simple typo / omission on their Air 3 release notes from last week no doubt.
