DJI Dcinelike and H264 Mini 3 Pro
Just throwing a heads up here in case no one has come across it yet.
I usually film in H264 on my mini 3 pro and normal colour profile.
Today I tested dcinelike and had it on H264 as normal.
When i got home, none of that footage will either play in Windows Media Player (although VLC happily plays it) or shows up as a media file in Davinci Resolve Media Pool.
Loads of research and some more testing, I now know that D-Cinelike in H264 jsut will not play in Resolve or media player.
Record your d cinelike in H265, and its fine in both.
I’ve managed to convert the footage I got today into a 10 bit H265 profile using Handbrake, but what a PITA.
Hopefully this might save someone else the hassle.
I’ll just use H265 for everything going forward
It’s been fine for me, but I use a Mac. Plays fine in IINA and Final Cut Pro opens them fine for colour grading.
Isn’t there a codec you need to install for it to play in the default Windows player. Look in the Windows Store.
I’ll fire up the Windows 11 laptop next time if I can remember.
I film on the Mini 3 at weddings in D-Cinelike H264. It won’t play in Windows but works fine in DaVinci.
Sorry, yes I should have mentioned Windows
Do you have the full version of davinci or basic?
I’ve got the full Studio version.
I did read somewhere that might be part of the reason
so is anyone else having a weird issue with downloading footage or dragging it onto your editing software for it to say it wont go over?
cause i have seemed to of ran into an issue of the MP4 H.264, ,D-CINELIKE profile but others are fine and on the pc it wont show a thumbnail and wont drag onto the software basically useless footage.
anyone having this issue?
Moved your post to the thread where this has been discussed.
i have the samer issue buddy i have noticed seems to be the h.264 d-cine profile onl;y thats messed :frowning: every otherr weorks fine and im gutted as i chased a paramotor and got some alright footage but duno what to do witth the footage :frowning: cause i cant edit it.
Any other machine to try it on ?
Does it open in handbrake ?
no other machine to try it on aand not tried handbrake
Worth a go.
Got a clip you can share via https://wetransfer.com/ to see if others don’t have the same problem?
  • Which Windows version are you on?
  • Does it play in VLC?
im on win 10 and yea it will play on VLC
I spent hours converting mine with handbrake, but it was so hard to edit it (stuttering) in davinci i just gave up and deleted the lot.
Thankfully it wasnt something I was that bothered about.
Im jsut going to record everything in 265 from now on. It might even tempt me to try out 60fps as that gets locked onto 265
I had some issue with my DJI FPV when I first got it, went here…now able to edit /play and render 264 / 265
Anyone willing to share the original of one of these files that doesn’t play ball in Win10 or Davinci Resolve … to see if my laptop treats them differently?
Albeit from my old MP - no issue with 4k H.254 DCinelike … having just taken a test clip.
Tend to always use D-Log … since DR has the colourspace converter for it.
Must remember to reset my MP to D-Log.
Here’s a screenshot off the OLED TV which I use to check the colour grading, it’s Dji FPV D-Cinelike H265 which I’ll admit I hardly use….
Taken earlier to test.
I was meaning an actual original video file to try on my setup.
