I would be careful. There are a host of cheap tablets, mostly using MediaTek hardware and, like this one, running a low resolution 1280 screen. Sometimes if you run diagnostics you may find that the claimed spec is higher than what is really inside the case. Avoid.
It is worth while spending more on something better and a “namw” brand. I know from experience that the cheap bargains can turn out to be not fit for purpose
Well, I don’t want to buy an iPad Mini and would rather stick with Android. It sounds like I may need to wait and hope that Litchi supports more devices?
Hi, I’ve just started using a Teclast M8, good spec and top end screen resolution, used for Autel Evo but should be ok for anything drone, C usb connector, 8.5 inch screen, fits controller with adapter fine, it is not on the compatibility list as no SIM fitted which seems to be the criteria for some reason, so downloaded App to phone and sent to tablet using Send Anywhere… all works great and lovely big bright screen, that is only APP on it apart from a few pre installed but turned most off, also from Amazon… use L200 type sun hood if needed. Cheers. Ps. £99.99
It seems that unless the device, Tablet has a SIM card fitted then it won’t appear on the PlayStore list as being compatible, when of course it is, I don’t think it has anything to do with processors or memory just not having a SIM card option… but of course you can download APP to phone and using something like Send Anywhere copy it to the Tablet… which I’ve done and all works fine… Cheers
Go for a refurbed iPad or phone from Amazon. They’re generally really good quality (an empty iPhone 6s cost me £150 - as opposed to £7-800 for a new 11 - for flying the mini) & there’s still a guarantee & returns apply as normal. You still get iOS upgrades & the apps are optimised for Apple stuff before Android.
Apple are overpriced & overhyped in general, but sometimes you just have to hold your nose.
