Ever since getting my Inspire I’d looked for someway of FPV without having to use the X5S.
Although I’d seen youtube examples, they just seemed a bit clunky to me, now though with the 03 air unit it’s looking like I can cobble something that’s to my liking.
Having the Bambu Lab X1C, I have a much wider choice of filament to play with, I’m drawn to the Bambu Lab Carbon Fibre PLA as it prints very accurately from STEP files.
As per title the parts used will be…
1, 03 Air unit
2, Speedybee FC
3, Foxeer M10Q-250 GPS
4, Mateksys Digital Airspeed Sensor
5, ZOHD 3500MAh Flight pack
6, LHCXRC CNC Machined 03 Housing.
7, Unknown number of hours designing prototyping.
Hi, nice to see people modifying these drones.
Spent many years building my own.
This little mount is ideal for the camera, I will have a look for the step files.
Good luck.
@Equatol Same here too, thanks so much for the offer, as I’m including a pitot tube on the camera mount, I’ve had to design from scratch…
I have two styles of pitot hence two different cap designs now printing.
Cool project, and love modifications. Only concern I’d have, is to check whether the O3 will go to full power mode without an “armed” signal from a flight controller. I have a feeling (and may be wrong), you can’t set the O3 to full power mode all the time (like you can a vista, etc.)
You could FPV in the way you saying with a vista, or even analogue (or those other HD systems I guess).
Anyways. Cool to see modifications, just thought Id ask whether you looked into this (and I may be completely wrong!)
Seems what I’d seen/remembered was correct. Can use an Arduino etc to provide an permanent arm signal, but someone else stated was annoying as need a separate RX.
