I went to charge my DJI Mini 2 today.
One of the batteries won’t charge and just sits there with all four LEDs flashing three times, pause, flash three times, pause…
I’ve tried all three slots on the hub, just in case, same issue in each slot. The other two batteries are both charging fine.
Couldn’t find a sequence / reason code online for this, anyone seen it before?
It’s currently still hooked up to the charger on the offchance it’s in a hibernation state or something.
I’ve opened a ticket with DJI but I suspect it’s dead
Have you tried charging it by itself out of the hub? Could be hibernation mode? I remember seeing something with the MA2, if your battery was in hibernation mode you had to charge it by itself not in the hub to wake it up (something along those lines, I’ve been to sleep a few times since)
I haven’t, no…
Just charge it in the drone you mean?
Would that make a difference?
I’ve just found this in the Mini 2 manual Rich
Looks like its a damaged battery.
I skimmed the manual too
I think I was just skimming the light flashing patterns though, not the text
Thanks Steve, looks like it’s a deadun!
Yeah you would think a damaged battery warning would warrant a picture of light sequence but apparently it only warrants a tiny line of text
Jhdee
21 May 2021 13:08
7
Maybe time for a claim against DJI - probably damaged due to the “non-self discharge” saga
Thats a good call John, worth an email at least
Jhdee
21 May 2021 13:12
9
I’ll see what their support says, if they won’t replace it I’ll just go back to Argos for a replacement
Jhdee
21 May 2021 13:19
12
I’ll send them a link to the first post here
Anyway, I’ll give them a few days, if no join then I’ll go back to Argos for a swapsie.
Have you tried putting the battery into the drone and turning the drone on?
If this works leave the drone running until it connects to the phone/remote. Then turn off and try the charge process again. This worked with mine when the lights were flashing and the battery was not charging.
I did indeed, but it wouldn’t power up at all.
This might help explain .
My Mavic Mini fly more combo is not charging correctly. I put 3 batteries in the charger, and on all of them, 2 lights blink over and over but no charging. If I install one battery, it usually starts charging normally. But when I put a 2nd or 3rd...
Which post on that forum thread?
Even the title looks different to the issue I’ve reported here.
I think Don is talking about the button on the side of the battery bank. Press and hold.
Worth a try.
He might be…
But no dice there either, was also one of the many things I tried
