Probably something to do with the fix (“optimising the correctness”?!
) for the battery level indicator?
I know I was informing you it can be changed to a number of options with a single press or a double press
I will check it out, I just got the M3 connected to the RC so will check what it can do better when I take it flying.
So, now that I’ve got v01.00.0201 installed, the 2-second option for the Hyperlapse has appeared. Excellent.
But… still no sign of portrait mode for either FocusTrack or Panorama.
Anybody else seeing those options now?
I haven’t seen a firmware update for the batteries, when was this released?
Today.
Has anyone tried the controller with the Air 2 yet? This is the one thing holding me off from getting the mini3 pro, I was going to pull the trigger on a SH Mavic 2 pro with the smart controller.
The Mini 3 Pro RC Controller won’t work with the Air 2 sadly, Air 2 is Ocusync 2 and Mini 3 is Ocusync 3, the Air 2S has both 2 and 3
Did you read this further up the page? So in theory the RC should also follow? Or is it only the RC that uses ocusync which doesnt make sense
“ The DJI RC-N1 remote controller can also be used with DJI Mini 2, Mavic Air 2, DJI Air 2S and DJI Mavic 3
(requires DJI Fly v.1.6.1 or late”
Yes oc 2 and 3 but the RC display for the mini 3 pro is oc3
Strange owning a 2S and it’s Ocusync 3 that you thought it be added to the compatibility list but according to dji website it’s not.
[quote=]
Compatibility
DJI Mavic 3, DJI Mavic 3 Cine, DJI Mini 3 Pro
[/quote]
Not yet, it might still be added
I think it will be but I obviously can’t say that it will be or even when
DJI RC Remote Controller Firmware: v01.01.0300
RC:
-Fixed issue: inaccurate compass appeared in some scenarios
Is there new firmware available today? ![]()
DJI’s poxy website release notes are still dated 30th June ![]()
If so, anyone got any release notes they can share?
Was looking for some text / words, so it shows up in a search result.
Ta ![]()
Yes.
Improved the 360 images for the sky and a couple of other bits.
Let the early adopter beware (as with all these updates from DJI)
The Mini 3 refused to take off before I updated it.
The motors just stopped when I tried.
After updating it took off.
This was in Birmingham.
