Be prepared and fly freely with peace of mind with 34 mins of max flight time with DJI Mini 3 Pro; 38 mins of max flight time with DJI Mini 3.
Tips
Measured at a constant speed of 21.6 kph in windless conditions.
In The Box
Intelligent Flight Battery × 1
Specifications
Model: BWX162-2453-7.38
Capacity: 2453 mAh
Weight: Approx. 80.5 g
Voltage: 7.38 V
Charging Voltage Limit: 8.5 V
Battery Type: Li-ion
Energy: 18.1 Wh
Max Charging Power: 37 W
Charging Time: 64 mins (with DJI 30W USB-C Charger and the battery mounted to the aircraft)
Charging Temperature: 5° to 40° C (41° to 104° F)
Recommended Charger: DJI 30W USB-C Charger or other USB Power Delivery chargers.
Compatibility
DJI Mini 4 Pro*
DJI Mini 3 Pro
DJI Mini 3
When using the DJI Mini 3 Series Intelligent Flight Battery, DJI Mini 4 Pro’s propulsion performance and flight time will be reduced, and the total weight will exceed 249 g. Always check local laws and regulations before use.
DJI Mini 4 Pro Intelligent Flight Battery
£59
Overview
Provides a max flight time of 34 minutes*, allowing you to fly and create freely with peace of mind.
Tips
Measured in a controlled test environment. Specific test conditions are as follows: flying forward at a constant speed of 21.6 kph in a windless laboratory environment at 20 meters above sea level, in photo mode (without photo taking operation during flight), with Obstacle Avoidance Action set to Off, and from 100% battery level until 0%. Results may vary depending on the environment, actual use, and firmware version.
In The Box
Specifications
Model: BWX140-2590-7.32
Weight: Approx. 77.9 g
Capacity: 2590 mAh
Nominal Voltage: 7.32 V
Max Charging Voltage: 8.6 V
Energy: 18.96 Wh
Charging Time: 70 minutes (with the DJI 30W USB-C Charger and the battery mounted to the aircraft)
58 minutes (with the DJI 30W USB-C Charger and the battery inserted into the Two-Way Charging Hub)
Recommended Chargers: DJI 30W USB-C Charger or other USB Power Delivery chargers
Done it. At 15.42, just a few minutes after reading the email notification from DJI, I received the purchase confirmation. It was all over in a cloud of dust and debris before I knew what had happened.
Although my Mini 3 Pro is less than a year old and I’m perfectly happy with it, I have a motive. I have a good friend [and his girlfriend] who dearly would like a Mini 3 Pro but isn’t in a financial position to get one. So I’m going to give him mine. The whole kit - 3 spare batteries, charger, props, ND filters, SD cards. Should make them happy.
It quotes on the datasheet that the mini 4 battery is only compatible with the 4 but as they are basically the same as the 3 other than the weight and mAH ( and voltage ) I am wondering what the out come would be
After getting burned with an original smart controller that rapidly became obsolete im glad ive resisted all the future controllers for that reason.
Again it seems they’re very quick to ditch support for them.
You’d think, but I can’t find it on those sites, it’s not listed. Which is extra strange considering the DJI site says it’s available through their site and official vendors. Argos and Very sell Mini 3 pro etc, and a 2 day delay in making it available is pretty bad for early sales.
I can’t find any statements or announcements from either site about the launch, and just wondered if someone has a scoop.
