DJI Power 500 / 1000 (portable power station) - Rumours, leaks, gossip and general discussion
Here’s one for the DJI fans :blush:
Word on the street is that they will soon be releasing a portable power station, with the catchy title of “DJI Power 1000”.
I’m not sure what it’ll offer over all the other existing power stations from the likes of EcoFlow, Bluetti, Jackery, Anker, et al, but from the model name we can safely assume it’ll be a 1000Wh unit.
Hopefully they won’t restrict the power output with a firmware update when in CE mode :smiley:
If you see or hear any other rumours about this new product, post them here!
I noticed that being mentioned a couple of weeks ago … but forgot to mention it on here.
With so much competition in that market, I can only imagine it being a re-badged version of one of the main makes.
Perhaps one that looks different, but basically an existing one that’s had ports moved about to make it look different.
More leaks this morning.
Alongside the 1000Wh version which weighs in at 14kg there are also rumours of a 500Wh version that will weigh 8kg.
Starting to see a few companies offering these powerbank options nowadays, Bambu Labs are also bringing one out, they must know something we aren’t being told, no doubt we are looking at major power outages with the insistence of EV vehicles and chargers, before they even provide further power stations to cope, I keep seeing old power stations being bulldozed, but no replacement beforehand, worrying times ahead
DJI Power 1000 Parameters
Weight: 13kg
Power: 1024Wh
AC input port - X 1
Interface:
  • AC power output port - X 2、
  • USB-C - X 2,
  • USB-A - X 2 ,
  • SDC - X1,
  • SDC Lite - -X1
    Temperature range: 10º C to 45º C
Yep, will be most interesting to see full specs esp. charge-time. We live off-grid here in deepest Northumberland (mega Trojan (recently Rolls) deep-cycles serve the house/inverter etc) but also use a raft of portable power-packs around the house in evenings (then recharged in daytime via wind/solar). Started off with lesser-known Awanfi/Huarigor/Yose/Fluoreon then onto the branded AllPowers/Bluetti/EcoFlow/Aferiy/Dabbsson. From c. 390Wh to a (combined) 5330Wh. The technology has evolved immensely - what used to take up to 7-8 hrs to basically trickle-charge Li-Ion at 60w we can now get to thump in 1800w (max, variable) to charge in less than 2hrs using the latest EV-grade semi-solid state LiFePO4. Our main criteria is the 2hr bit (eg. EcoFlow/Aferiy/Dabbson, at respective max settings, be it switch or app) as that’s the time our backup genny runs (if needed) to recharge the Rolls batts. In winter if we can get it sub-2hrs, we’re OK :slight_smile: . Obviously the bigger Wh the bigger the biceps needed, but those (Dabbsson (2330Wh + 3000Wh batt-pack) / bigger Aferiy (2000Wh) - c. 25kg a pop :muscle:) you tend to leave in-situ, the more mobile (Aferiy-1248Wh/EcoFlow-882Wh at 14/11kg) are luggable. One thing I’ve found is that AllPowers ‘do’ like their fans, though :thinking: :exploding_head: Anyway, enough from me, lets see what DJI has to offer :smile:
I think they’ll struggle to be competitive in this market, given the big players that already dominate it.
:point_up_2:t2: Thanks @PingSpike now I need to clean coffee off the wall… :rofl:
Anyone seen what input options these have? solar etc?
If they are not LiFePO4 powered then I’d look at other more established options
Charging speed: charges in 70 minutes
Battery type : Lithium
Service life: more than 80% of the capacity after 3000 cycles
Input type: Solar input, car charging, municipal electricity
Solar input: 400W X 2
Total power: 4400W (4000W daily)
Full load output time: 1.4 hours
Noise: 23dB ~ 28dB
It can act as a backup UPS power supply, automatically switching to a mobile power supply in 20ms of power outage.
:astonished:
DJI Power 1000 - 488 usd
DJI Power 500 - 293 usd
That’s pretty good pricing compared to competitors
That’s almost too good, especially for DJI.
Is this legit? Who knows… but as this is a rumours thread:
https://x.com/dave_beno/status/1733161521767936199
https://x.com/dave_beno/status/1733165275833647462
On that basis we will see DJI releasing a 3d printer at some point, which will print 30cm x 3 and a benchy in 15 minutes!
The powerful Power 1000 has a battery capacity of 1024WHr (about 1kWh) and a maximum output of 2200W, while the lightweight and portable Power 500 has a battery capacity of 512WHr (about 0.5kWh) and a maximum output of 1000W. Both power supplies offer 70 minutes of charging, ultra-quiet operation, and fast power for DJI drones.
DJI Power 1000
Powerful performance, multi-scenario charging and discharging, fast charging for drones
With a battery capacity of 1024Wh and a maximum output of 2200W, DJI Power 1000 can provide stable power to 99% of commonly used devices, charging a mobile phone 57 times, a digital camera 59 times, and a drone 12 times. can.
Whether camping, driving, content creation, or family emergencies, DJI Power 1000 can ensure large capacity and stable output, easily meeting the power consumption needs of multiple scenes. DJI DVR is designed to meet the power needs of multiple scenarios.
DJI Power 1000 can be used for DJI Power SDC Super Fast Charge on select DJI drone batteries with compatible accessories, DJI Mavic 3 Series Smart Flight Battery, Air 3 Smart Flight Battery, Inspire 3 TB51 Smart Flight It can provide high-speed power supply to the battery, M30 TB30 Smart Flight Battery. It takes just 32 minutes to charge the Mavic 3 series battery from 10% to 95%.
Meanwhile, DJI Power 1000 has nine ports, including two 140W USB-C output ports with a total power of 280W, which is 40% more than the typical dual 100W USB-C output ports on the market. ing. It can easily meet the power needs of most USB-C interface devices and supports PD 3.1 up to 140W charging specifications, allowing you to quickly charge your 16-inch MacBook Pro.
Multi-safety design and quiet operation
The DJI Power 1000 is equipped with a lithium iron phosphate battery cell that can be used for 3000 cycles, achieving a lifespan of about 10 years even with heavy use. Equipped with BMS intelligent battery management system, when a safe power threshold is exceeded, the charge/discharge protection mechanism will automatically turn on and will not restart until the power environment returns to normal.
In addition, a full range of temperature sensors, power outage protection, built-in UPS mode, the entire machine using flame-retardant materials, and high-strength construction with a load capacity of up to 200kg can provide even more comprehensive security protection for the power supply.
DJI Power 1000 is designed for safe operation. The 23dB during charging is lower than that of a typical household refrigerator, so it does not cause noise problems even in quiet environments.
Flexible charging options
DJI Power 1000 can be charged using commercial power, solar power, or vehicle charging. In fast charging mode, it can reach 80% capacity in just 50 minutes, and the fastest time from zero to full charge is 70 minutes. Solar charging for DJI Power is possible by connecting it to a solar panel via the DJI Power Solar Panel Adapter Module (MPPT) or DJI Power Car Charger Plug to SDC Charging Cable.
If you travel by car, you can charge your DJI Power 1000 from your car’s cigarette lighter socket using the DJI Power Car Charger Plug to SDC Charging Cable.
DJI Power 500
Lightweight and convenient to carry
With a weight of only 7.3 kg, a battery capacity of 512 Wh, and a maximum output of 1000 W, DJI Power 500 can charge mobile phones approximately 28 times, digital cameras approximately 28 times, and drones approximately 6 times, making it lightweight, easy to carry, and capable of charging short distances. It is suitable for scenes that require light power, such as outdoor leisure and entertainment, and family emergencies.
With compatible accessories, DJI Power SDC Super Fast Charge can also be used with select DJI drone batteries, allowing them to take off in as little as 30 minutes.
DJI Power 500 also offers mains, solar, and on-board charging options, and fast charging mode in a mains environment takes just 50 minutes to reach 80% capacity and 70 minutes from zero to full charge. Complete in minutes.
Additionally, the DJI Power 500 can also be charged via the two 100-watt USB-C ports on the main unit, providing a total of 200 watts of power and can be fully charged in about 3 hours. This gives you the flexibility to choose the appropriate charging method, whether indoors or while driving.
Two 100W USB-C bi-directional ports support both input and output and support PD 3.0 fast charging protocol for efficient output and input.
With eight ports, the DJI Power 500 is a practical device that can charge multiple devices at the same time. It can also be connected to various types of solar panels, power cables, and adapter cables to meet various types of charging and discharging expansion needs.
The DJI Power 500 also has the advantage of ultra-quiet operation, with power delivery volume down to 25db, which is lower than most home refrigerators. The DJI Power 500 also features ultra-quiet operation, with a charging volume of 25 dB, which is said to be quieter than a typical household refrigerator even in a quiet environment.
Safety always comes first, and the DJI Power 500 features a complete safety design, from the main body structure and battery hardware to the system software. Equipped with multifaceted protection functions such as BMS intelligent battery management system, lithium iron phosphate battery, omnidirectional temperature sensor, and power outage protection, it boasts complete safety.
The price in China is approximately 71,000 yen for the DJI Power 1000 and approximately 43,000 yen for the DJI Power 500.
*Release date and price in Japan are yet to be determined.
https://x.com/D2Help/status/1733223263327662253?s=20
Oooh! “Print the Mini 5 Pro on your own DJI 3D printer in the comfort of your own home” :grin:
