Of course, you’re all absolutely correct. I should have faith in the RTH/controller and picking it back up if I move it a bit.
I do suffer from excess swirlies in my eyes, even with sunglasses and this is causing me to be overly concerned with always knowing where the thing is.
Not sure which intelligent flight modes you have if you have home lock you can try that out see how comfortable you are with it first then apply when you need too.
Home lock works by having the drone fly to or from your home position in a direct line.
It doesn’t matter which way the drone is orientated if you push right stick forward (mode2) it fly away from home point in direct line. Pull stick backwards it will travel direct in a straight line towards home point.
You can pan the drone etc while going in either direction.
I’ve used it couple of times when got disorientated at distance. Remember heights of obstacles between you and drone though.
I know you’ve already mentioned the LED light on the bottom of the MA2 but I’ve found linking the Function button on the controller to that light. Sometimes when doing sunset pictures on low light a quick double tap of that can help when locating it!
Also Polarised sunglasses are a must for picking it out on sunny days!
