Emax Tinyhawk 2 Freestyle
Well done on not losing it. Have you got any BLUE threadlock? If not buy some. Always worth checking your screws before going out, and if out for a while check regularly. I lost one from a motor (thank god only one… before). The vibrations unscrew the bolts, so yeah threadlock for the win (BLUE I repeat!)
So you flew LOS? Wow. With regards the goggles, might be worth joining a session and trying different types if you have a strange “fit” before investing in any. It is a long term investment. I personally didn’t get on with the HDO’s, etc I’ve tried at meets in the past, and EV800D’s I had… hmmm.
Chris. I’m in Bristol next Tuesday. When I finish, if you’re free, you can try my gear.
Might be a bad idea. It has nylon standoffs and the threadlock might destroy them? @Steviegeek knows
Oh is that right… Oh damn… ummmm… are the baby hawks stand off nylon… (Off to check)…
I might be wrong. I usually am :grin:
Trust you on most things Karl… though 2.4 isn’t half of 5.8 :wink:
At least make sure they’re tightened then :slight_smile:
Thanks for the offer Karl :pray: … but I don’t trust myself with my gear at the mo :grimacing:
It may surprise you but the dipoles supplied with the goggles are more efficient than the commonly used circular polarised skew planar antennas.
A dipole has a gain of 2.15dBi, where as a standard three lobe skew planar has a gain value inbetween - 1.7dBi and - 2dBi.
The advantage of a skew planar is its ability to reject multipath reflections. When a circular polarised wave is reflected its polarity is reversed, so a RHCP becomes LHCP. This is a great benefit when flying in such areas as bando’s. In wide open spaces, where the likelyhood of reflections is much reduced I will quite often use a linear dipole if I’m wanting greater range. This is one reason why you seldom see skew planar antennas on 2.4GHz RC controllers and Receivers.
Up to you. My stuff is built to crash. On about the goggles really
Good plan.
I find that Karl’s HDO2s nearly focus right for me, but not quite. The skyzone 04 range has just a bit more focus range.
Interesting. As hdzero handles multipathing well, maybe I should test some of these
Yes, it was fine, just like DJI I suppose, but a tenth of the size :wink:
Yeah, it’s a good shout. Especially with my eyesight and a massive head, don’t want to get something and then have to return it.
Sounds like me. I take the largest hats you can buy and also have terrible eyesight, especially in my left eye. I use varifocals and seem to need a new prescription every year as I get older. Hence why adjustable focus rather than inserts is preferable.
Not sure. I did know, as I ordered some glasses of the internet a few years back. I’m sure it’s a lot less than +/- 6 though. I’ll check them out.
I think HD0 uses MIMO, similar to DJI and my Connex system, whereby the signals off each antenna go through a clever combining process.
Exactly. I had to wait 3 months in Sea Scouts whilst they custom made me a hat. Probably why my Mum never liked me :joy: It’s my left eye that is shot too, a stigmatism, rugby ball eye ball apparently. Even the GADC cap was too small. I had to use the heat gun to stretch the plastic straps :man_facepalming:
I have a couple of hat stretchers… all the way from texas, where they know all about big hats.
Head size has not been an issue with any goggle… just eyesight.
Im sure i heard somewhere that the angle of the patches relative to each other are such that if the incident incoming wave lags (because of a reflection), then the other patch is used.
You are having a laugh. I wouldn’t leave my office with these on, let alone my house. The curvature of the mask is that narrow, the sides dig in to my cheek bones :confounded:
