I took advantage of the good weather on Wednesday, took the afternoon off and set out to take some actual footage, instead of just flying around for practice. In the end I didn’t get a lot of usable material, but I certainly learnt a lot.
Always record everything.
The first place I stopped was up on the top of the valley. I thought I’d spend a little while flying around and getting comfortable with the location before I cued up any shots. Within minutes a couple of fighter jets on training runs tore up the valley below. I’d almost certainly have missed the first, but they always come in pairs, so I’d probably have got the second. -
Check your levels.
The first 5 minutes or more was woefully overexposed because I didn’t think to check the level from last time I was out. -
Don’t touch the yaw.
That probably just needs to be translated as, I need a lot more practice getting a soft touch with the yaw control. Every time I use it seems very jerky, even in cine mode. I’m not sure there’s any setting that I haven’t tweaked already that can help with this. -
Sports mode is fast.
High speed low level flights might look cool but the ground can come up to meet you really fast. Fortunately I only ditched it into some springy heather, and it was a good opportunity to test “Find my drone”.
By the time I was getting my eye/hand in at the second location, the wind had really picked up and the poor little mite was struggling to make headway into it, so I didn’t stay too long. But I did get enough to put together this very short piece that also served to help me up the DaVinci Resolve learning curve.
