Just replaced my ESC and thought everything was hunky dory, I have OSD but no controls. It all links to the vista fine checked my ports for the FC on line and there right, but when I power up and go into BF none of the Aux switches work or stick movement.
Can anyone shed any light on what this might be please, dont really want to strip it down as to go through it all again if possible
I’m feeling the same way about the prospect of fixing my Nazgul at the minute, but the Big Meet is getting close now and I know I’m going to have to grit my teeth and just get on with it.
Its my Nazgul thats the problem Dean, as for stripping down I mean taking the top off and FC out to check. Hence is there anything more I could check software side of things before I go diving back in…
I have power to the ESC which in turn is powering the FT & CADDX unit, all the lights on the FC indicates things are ok. I have BF OSD into my goggles and my controller is linked to the CADDX unit. But when I power the quad up and link it to BF none of the AUX switches work and there is no stick movement showing…
Its as if the FC is not talking to the ESC? which can only be Iv wired up wrong which Im sure I havent ? or there is something not checked in BF…
When I had this after putting the new stack into my Nazgul it turned out I’d mixed up the TX/RX connections between the TBS RX and the FC. And I’d checked them. Lots.
It does sound like a receiver issue. I’ve done similar before and a simple changing of wires sorted it.
However, this was with me using crossfire and I think you will be using the DJI controller?
I’m sure you have but it may be worth double-checking the tx/rx wiring
Could be the protection diode for the sbus on the vista like you had before? But if you havent changed any of the wiring from when it was working its unlikely
Would you know which 1 of the plugs is my controller?
Its really strange as the top 1, they have made the plug hole ( On the board ) larger than the plug from the Caddx unit hence you have to avoid the top pin VTX not sure why this is done that way??.
