Mine behaved fine but then I did the update at home. Not sure if that would have made a difference.
I had an issue today,
The first battery asked for a compass calibration, which I did then decided just to fly straight up and do a few shots
The second battery at a new location went fine, other than I noticed at around 10 meters it kept dropping, I put this down to the bottom sensor over water
The Third battery, the same location as the 2nd (over water) took off and hovered, checked the controls then moved out over the Lake. Then oh crap! SD card appears to be slow error!
and then a disconnect âAircraft not Connected to RCâ
I had no control for a few seconds, the Mini 2 just hung there
Then Return to home kicked in and as it shot up I got it back
I brought it back and landed and called it a day, didnât want to risk losing it over water
I havenât had time yet to check the flight logs
Is this with the newest updates? Iâm thinking I might not bother if so.
It is. Fly app 1.4 seemed to go ok on 15th, Flight as normal on 16th, 17th firmware update just before flight and then it all went downhill within first minute of take off.
Being involved in software development Iâm forming an impression that after constant iterations and fixes upon fixes DJI might have created a bit of an unmanageable monster with their software.
Confirmed.
Shame it took them four days to announce it
So am I right in thinking these firmware updates will not affect the Mini 1 because it doesnât have the RC-N1 controller ??
Think I need a test flight this afternoon - donât want to go out on a shout for a lost dog and have the drone disappear too
Yes, confirmed. This is Mini 2 only.
Still doing a test flight this afternoon - whatâs the chances DJI have stuffed the Mini 1 by changing the Fly app ⌠I wonder
i suspect it may have been something with the update.
I donât do updates while Iâm out, always skip them until I can do them at home and do a test flight somewhere safe after.
Same here, itâs the sensible thing to do. Itâs not that I donât trust updates but I prefer to do them at home before I go out and fly. Too much can go wrong when youâre out and about.
Yeah, for me itâs that I want to know that itâll handle the same as last time I flew. So that I donât waste time, and Iâm too impatient to wait for the update when I want to fly!!
Same here and an expensive lesson learned. Iâd been checking for an update after the fly 1.4 update. Nothing for two days, until I come to fly on Saturday.
I shall treat an update suggestion in the field as bad weather and do it at home.
Goods news, DJI analysed flight logs and are replacing my Mini2 - result! Iâve asked what went wrong exactly and will share if I get a reply.
Great news @Sidee ! Be great to hear what they say
Update from DJI on the cause on my flyaway â According to the data analysis, the flight accident is caused by a possible compass interference. There is no pilotâs error and we determine to cover this case under warranty. For safety concern, please avoid flying near any tall buildings, steel structures, mountains, rocks or even trees which may affect the accuracy of the on-board compass and block the GPS signal.â
Must be my magnetic personalityđ
Seems generic but at least you got a response.
If itâs your personality youâll have to give up flying for good
Well done DJI for replacing it without Care Refresh. Shows itâs well worth putting in a claim however remote you think your chances of it being accepted.
Loves a happy endingâŚ
