Flying in light rain/drizzle?
Done a search and can’t find much on this so I am hoping the wise owls of the forum can help…
The other day I went to fly. The weather was mainly dry and sunny but just when I was ready to launch it started to drizzle. I know these drones are not waterproof in any way and so we shouldn’t get them wet but it was very light drizzle. Fly or not fly?
In the end I waited. It was clearly just a shower and it didn’t amount to much but it got me thinking… can we fly if there is a bit of drizzle in the air? How much is too much?
I had the same Saturday morning whilst trying to photo the church in a FRZ, I waited for a gap, wouldn’t risk flying in the rain in case it caused any problems, water getting into the electrics and causing a crash or loss of control would be my main concern.
Rain around - drone on ground!
Sounds reasonable.
I’ve flown in wet conditions several times, sometimes unplanned, once just to test. Above low cloud usually ends up with quite a bit of moisture. But mainly it has been most, drizzle or rain. The motors are brushless, and the the same that are used in submersibles, therefore rain is fine. That said, the main drone internal electrics are not fine with water ingress. I’ve taped up the battery gap and SD card slot, and never had an issue. Obviously, still a risk though.
I think the majority of flyers have been caught out and brought it back wet, be it drizzle, dew or clouds ;o)
Would I set off in the rain, no.
As @clinkadink said - the motors most likely to get wet - but electrically no issue - and sealed bearings will have no issue.
Other observations …
  1. Internals get pretty warm so, in drizzle, the amount of ingress not that high and moisture would evaporate, and in rain most rain will go past the drone. Fine spray from props in rain equates to drizzle.
    Some larger models have an internal cooling fan (my MP) that draws more air through the body - but all the fog/drizzle that’ it’s been subjected to (over almost 6 years) has never been an issue.
  2. External camera lens moisture will cause weird image distortions due to optical properties of water droplets - but otherwise no problem.
  3. Internal camera lens fogging. Had that after flying in warm humid conditions and then taking the camera into the chill of an airconditioned room. I always travel with a plastic zip bag large enough to hold the folded drone and several silica-gel packs (that I take vac-packed - just in case), and never had long-term issues. Same solution if you suffer the fogging after flying in drizzle.
Remember - rain/drizzle has a very low electrolytic properties, so chances of shorting anything relatively low. Likewise, residual deposits after it has evaporated exceedingly low - hence no long-term issues.
Also - as @clinkadink said - if it’s rain or significant drizzle - and for a longer flight than a quick up/photo/down flight, tape over upper body joints.
The bigger question with drizzle/rain - is there anything worth photographing/videoing? Probably not.
At least getting above fog can provide some great images.
Not “recommending” it. But, if there’s a need, a short flight in light rain / drizzle / fog won’t be a very brief flight to disaster.
If it’s more than the very mildest bit of spit, probably unwise to fly in it. Even then you have to consider whether that’s likely to develop to worse rain during the flight.
Even drones rated for having ingress protection aren’t “waterproof”, they’re just more resistant to getting water inside. The internals and battery won’t like water very much.
Thanks for all the great replies… very helpful.
I think it is something we all make our own minds up on… for me I have decided not to deliberately fly in anything more than the very lightest of fine drizzle and even then only if I can be pretty certain that it won’t get much worse. Mist… may be if the shot looks worth it :slight_smile:
As for whether there is anything to photograph… a good photographer can always find something to shoot… but that is probably for another thread :slight_smile:
There’s guidance for flying in mist/fog conditions as part of an A2 CofC course.
Essentially, make a test flight in the fog for a minute or two, land, assess the accumulation of moisture and decide whether to make a more serious/long duration flight based on that.
In winter be wary of icing - it may be above freezing at ground level but below 0C a few metres up
IIRC someone on Youtube had an issue with icing
Icing can start forming about +4C on props. They change the pressure around the blades as they spin and thus the freezing point of water.
Not to fly unfortunately. Theyre water resistant to an extent but precipitation is the worst thing for the electronics. Put it in the hanger and wait another day
We know you like to follow the rules :wink: so this is for you :+1:
I’d echo what milkmanchris said; if you get caught out by fog or fine drizzle, no need to panic - but keep it in its bag if already precipitating.
Being a bit pendantic here but the blades don’t change the freezing point of water… that is always 0C
Props are aerofoils and they work by lowering the pressure above the blade and increasing the pressure below hence the blade wants to rise.
The drop in pressure will result in a drop in temperature (Bernoulli’s principle). So, although the air temperature might be say, 2C, as the air passes over the blades the pressure drops and so does the temperature. If that drop in temperature results in it dropping below 0C the water in the air will then freeze and it can stick to the blade.
This is the same principle that results in carburetor icing which can occur is quite high ambient air temps, up to about 30C, because in a carb the pressure drop is large and so then is the temperature drop.
LOL! I am being pedantic on myself now!
Water freezes at 0C as a general rule. Yes, there are circumstances where it doesn’t but those circumstances are outside the scope of the scenario we are discussing here.
It is fair to say that as a general rule, water freezes at 0C in a normal atmosphere.
There… I feel happy now :slight_smile:
Still incorrect … you missed out the word “pure” - find me any “pure” water in the free world.
Any impurity will impact the freezing temperature.
:crazy_face:
Yes… and pressure differences… and supercooling… and a whole bunch of other stuff that doesn’t really apply to a drone and its spinning blades :slight_smile:
But yes… being pedantic can backfire because there is always something someone can argue has been left out but I was just trying to help :slight_smile:
I’m just going to agree with @milkmanchris
If I go out in the dry and turns a little wet I’ll get my pics. If it’s already wet I’ll find something else to do. I’ve had my mini2 caught in a few showers now, take it home and let it dry out for a day or two. No issues so far.
I’m sure Windswept Robert left his out in the pouring rain overnight after crashing it, no issues for him either.
Everyone is missing the obvious.
I hate getting wet, therefore the answer is no!
