Hi. I am drone newbie who bought a NEO and loved the new expereince.
I have since bought an Avata 2 , Googles 3 , Motion Controller 3 and FPV Controller 3 .
At the moment I just want to play with manual FPV on a Simulator
I have started working through Joshua Bardwell’s lessons which are great.
I am using Liftoff and I have configured the FPV controller as he said. I had to “invert” the sticks as they were working in the wrong direction and I had to add “Deadband” as the drone was drifting. Everything seemed to be working fine
So I thought all was good following the lessons for throttle, pitch , roll and yaw…until I got to Lesson 4 for Turns
I dont know whether the problem is me , the simulator or the DJI Controller with the Simulator.
I roll into a turn then add yaw (as the video suggests) but the drone pitch down increases massively so I need to correct it to put it into a more moderate slightly nose down pitch.
Firstly welcome to the mad house
My advice in liftoff is to go in the control setting in the workbench i think it is and change the rates and expo setting to the numbers that are on your avata in the googles
you can make profiles for the rates expo etc and save them
There are also copys of the avata in the liftoff community workshop you just click to subscribe the drone or course you want
hope this helps
It’s normal to have to correct with pitch up slightly in a turn. It might help to visualise it physically by holding your drone/laying your hand out flat. Hold it still in a pitched forward position, add roll to one side, then add the yaw change. You should see that the nose is now pointing lower than how you started.
I’m doing the same course he expands on what he introduced in part 4 in the next video. He also later on gives some tips on making less wild stick movments.
