I took the drone out to film some fireworks tonight and when I started it up the front red Let’s came on for a couple of seconds then went out. I took off hovered about 10 ft off the ground but still the reds won’t flash so brought it back down as I needed all the help I could get for my first night flight.
When I looked at the settings there is no option to turn them on or off now. I know it used to be there but it’s not there now.
Now I know the last time I powered it up in the house to adjust settings they worked cause the wife was complaining about the flashing. All I have done since the last power up is update the app and calibrate the IMU.
Anyone else noticed this or am I just being really thick and looking in the wrong place. Needless to say I didn’t get any firework footage tonight
I think the Mavic Air ones turn off once you start video recording.
Would not like to swear to that without checking !. I am sure there is a on/off switch in the settings, as I turned them off last Friday to do the Firework Challenge Video!.
Tried power up in the house and still the same, come on for a couple of seconds then go out. Just looked on YouTube and it shows option to turn them on or off but I haven’t got this option
You could uninstall, download the ,.apk for an earlier version and install it.
For various reasons I’ve not gone past 4.2.21 … and that setting appeared last time I looked. I’ll double check for you if you decide to go that route.
Of course - that doesn’t explain how they ended up being switched off … unless one of those buttons is already set to switch them on/off, and you accidentally caught it.
