@TheBinman please post an image of your choice, captured by drone, for us to work on. Your image should preferably be in dng/jpg format, You are welcome to post AEB, a series of 180/wide panos. Please no 360’s.
Maximum file size is 100Mb for direct upload, the site can also accept zip and rar files if you want/need to compress.
If you can only submit a dng then we will happily create a jpg from your original, this is intended for display purposes so we can all see your pretty picture immediately
The Rules
All entries must be in jpeg or webp format.
Your entry must be a still picture.
Objects may be removed but nothing added. This means adding anything into the picture that was not there in the first place, swapping skies etc.
You may post edits with added objects, but they will not be considered for the poll
Create and post as many edits you like, but please tell us which one is your entry by clearly marking it “My Entry” on the top line of your post, EVEN IF YOU MAKE ONLY ONE ENTRY. Failure to do so may result in your edit not being included in the poll.
Entries can be submitted until 7pm on Sunday 24th December.
After entries are closed, a poll shall be opened for all forum members to vote on up to three of their favourite edits (if I remember and have taken a laptop with me). The winner will then get the honour of supplying a picture of their choice, captured by drone, for the next round.
@Kirky and @Leylo1971 if you can be bothered, could you each dig a pic out just in case Jason is not able to, please? Will give it another 24hrs. If no response from Jason then both of you go ahead and post a pic each.
