Hi all,
I have some FPV gear for sale. Hardly used, sat in a draw you a few years now so deciding to get rid. For sale is the following. For the Taranis, FuriBee X215, batteries and charger I’m looking for £350 or reasonable offers, postage is extra which I will sort after, but I imagine would be under £10 with a courier.
Description:
FuriBee X215 Pro It was purchsed in 2018 but I’ve never flownit (too scared!) These are the details on the drone from the manufacturer. With 3K carbon fiber material imported from England, reinforced by the aluminum parts, the airframe contributes to much higher maneuverability as well as the marvelous F4 FC and 4-in-1 BLHeli - S 30A DShot ESC. The combination of the most powerful 2206 brushless motors and aerodynamic 1200TVL CCD camera, 5.8G video transmitter and pagoda antenna allow you to get the high-quality image and get it transmitted without latency. 2 sets of unopened propellers included.
Main Features:
●Superior 3K carbon fiber frame , 30 percent lighter, 50 percent stronger, with 4mm thick arm, solid aluminum parts
●Advanced flight control system consists of FuriBee F4 FC, 4-in-1 BLHeli - S 30A DShot ESC
●Efficient propulsion system - 2206 2600KV high KV brushless motor and 5048 three-blade propeller
●1200TVL CCD camera , 5.8G FPV from more than 2km away,omnidirectional signal coverage
Specifications:
General
Brushless motor: 2206 2600KV
PC + fiberglass
Video transmitter: 5.8G 40CH 0 / 25mW / 300mW
Antenna type: pagoda antenna
2-in-1 LED buzzer: with four WS2812B LEDs, 4.5 - 5.2V input
Camera mount for GoPro Session: yes
Carbon Fiber Frame
Wheelbase: 215mm
Weight: 95g
Size: 175 x 225 x 60mm
Arm thickness: 4mm
Lateral plate thickness: 1.5mm
Aluminum part width: 5mm
F4 Flight Controller
MCU: STM32F405RGT6 32-bit processor
IMU: ICM20689 ( SPI ), up to 32KHz
Input voltage: 7 - 42V
Supported firmware: BetaFlight ( pre-loaded ), CleanFlight
Integrated OSD: yes
BLHeli - S pass-through: support
Automatic voltage monitoring: yes
BEC output: 5V 1.5A, 3.3V 200mA
Mounting hole spacing: 30.5mm
2-in-1 LED Buzzer Module
Operating voltage: 4.5 - 5.2V
FPV Camera
Image sensor: super HAD II CCD
Horizontal resolution: 1200TVL
TV system: PAL / NTSC
5D-OSD button: yes
Input voltage: 12V DC
Four Flourion 14.8V 75C 1300mAh batteries see picture
iMax B6AC Professional Balance Charger/Discharger
A Taranis X9D radio Control Unit with XBR. Mode 2. US Plug but with UK adapter.
Ideally selling as a bundle together but I would consider selling seperately if required.
I also have a FlySky FS-i6 controller (which doesn’t work with this dronebut is in perfect condition) selling separately. £50 not including postage.
I’m in the UK, Basingstoke, Hampshire based so pickup welcome. Or I can get a price for courier/postage fees.
If theres in no interest on here I’ll sell elsewhere but I thought I’d ask you first.
Thanks.
Andy.
