First attempt with new Mavic Pro
Nice. Check the condition of your props, or your frame rate as you have Jello in that vid. Otherwise well done.
Nice shot John
As Steve said check the settings of the video there is noticeable jello in that clip
Nice video
As Jeff says Mavic Pros have a nasty habit of this if you’re shooting anything above 30fps.
Thanks for the replies and advice had wondered what had caused the judder will try swapping the props .
Changing the frame rate might be a quicker and easier fix mate
Thanks will give it a go
