Morning pilots, just a quick question with regards to portable charging options, is there any reason why I couldn’t use this to charge my mini 2 batteries
Have you a link for it?
No but it probably will not fast charge the batteries as the max output is 2.4Amps/12w
The Mini 2 charge hub required a minimum of 15w for fast charging
An 18w charger is recommended
Ah right, was stuck in the back of the cupboard and I just thought about maybe using it as it’s compact and light and can easily pack in a bag. Never mind eh? Thanks for the heads up tho, appreciated
Try it and see, if the charge lights flash slow it’s slow charging which I would expect but you never know
hi @Diem197 I bought a power bank to use for my mini 3 pro batteries for when im out and about. I use the 3 battery charger I got from the flymore kit and plug it into this
it takes about 3/4 of an hour to charge one battery and as I have 4 batteries by the time ive used 3 of them I have one of thoes charged up ready. So far its worked out great. I normaly get 2 charged up before deciding to head off home.
Hope this helps.
Thanks for that, will take a look👍🏼
That one’s not available, but this one looks identical. Amazon…
