Hello from Kingston-upon-Hulli
Hi everyone, new to all this… “myself”, I guess, just like many, thought buying a drone and flying it would be a simple task. So off I set and paid hundreds of pounds for a high-end piece of kit. That was in mid 2023… I took it out the box…set it all up…flew it for all of 10 (yes ten) minutes…and that is as far as I’ve got. Perhaps a litttle too wary of losing something so costly or just plain chicken…I’m not quite sure…just need somewhere quiet and a guiding hand…any and all support will be greatly accepted…thank you
Exnavydavy
Hi @Exnavydavy and welcome to Grey Arrows :wave:t2:
Welcome once again!
Hi from sunny Blackpool
Hello and welcome, I’m not a million miles away in Selby/Goole
Maybe pop along to Barton and say hi in a couple of weeks
Welcome to the group :+1:
Hi @Exnavydavy and welcome to GADC.
Hi Dave @Exnavydavy and welcome to GADC :+1: :+1:
Hi @Exnavydavy from just across the river in Healing nr Grimsby!
Thank you
Thank you
Thank you
Hi Dave @Exnavydavy - welcome to GADC :+1: :+1: :+1:
Hi, @Exnavydavy welcome ex navy myself. Not too far away in Leven.
Hi @Exnavydavy and welcome to the GADC site
I’m very new to this too Dave. I was so nervous the first time I took to the controls. Taking it really steadily and trying things out in a really safe open space worked well for me. I looked at the criteria the CAA use for their A2 Certificate of Competence test, and worked through that: trying things out with the aircraft between about 5-30m off the ground, in a flat open space, with no obstacles nearby, and light winds. And it worked! My confidence has grown a lot. I’m still cautious, I rarely use ‘Sport’ mode, and stick to ‘Cine’ much of the time, especially when I’m over the area I want to photograph. But confidence comes with practice.
It’s natural to feel a bit apprehensive taking several hundred pounds in to the air, knowing one error could transform it into worthless junk, but I feel this nervousness is a strength, which will help keep you from making mistakes.
Welcome, good luck, and happy flying!
