Help a New Pilot Safely Get of the Ground - Edinburgh
Hello Arrow’s :wave:
My Name Is Chris and I live local to Edinburgh.
I have just got my first drone and I’m looking for some advice to help keep me safe.
Being a new Drone Owner and rather than take my normal approach to things like throwing all caution to the wind I want to take my time to get it right and keep safe even read the manual.
Although when I say new drone owner I did once buy a drone from our local costco, I took this out to a field and was home in around 20 minutes later with just the controller :thinking:
I have a few questions and hope you can help.
I understand that I need to take a test online to get my operators ID and drone registration this seems to be mandatory?
This will be have to be completed before I try to get off the ground.
I live in a street surrounded by detached houses, Can I take off from my back garden and fly so long as I keep to an altitude of 50 meters?
I downloaded the Drone Assist app and My area Comes up as High Risk Airspace controlled Traffic Region CTR Edinburgh
Does this indicate that I am unable to fly in this zone, The Red zone covers a vast area and would mean Id have to travel over 1 hour to be outside the indicated red zone.
Hopeful I may even find some locals to me and be accepted as a Drone buddy.
Many thanks in advance Chris.
Welcome @Chr1s :wave:t2:
You’re probably looking at Class D airspace, see if you can turn that option off in the settings somewhere.
And/or check out:
Where Class D airspace is off by default :wink:
Hi Ping Spike thanks for the reply.
I have now turned off the Class D setting on the App however the Red area is just the same.
It covers a huge area from my central position.
The view a shared location is not letting me log in using my arrows credentials, It could be that I have only just registered to use the forum :thinking:
How far away from the airport do you live?
Hi :slight_smile:
Google maps indicates I am 12km away from the airport as the crow flies
Hi Chris,
With Class D turned off, the map should look like this.
Hi SeaHunter :slight_smile:
This looks different from mines.
Hopefully I have managed to attach this :face_with_monocle:
Hi Chris,
Log in to the site below using your GADC username and password.
Zoom in to the Edinburgh area and ensure that Class D Airspace is unchecked as below
Thanks SeaHunter , I have given it a try several times but its not letting me access this part of the forum.
I get the error Error: Incorrect login details. Please enter your existing Grey Arrows username and email address.
I have emailed support but I think it could be due to me being a new member.
SeaHunter can you give me some clarity If i have permission from both neighbors either side to take off and land in my garden so long as I take to an altitude of 50 meters? is this permitted ?
Are you in a ‘congested area’ ?
Hi Milkmanchris :slight_smile:
I live in a street of detached houses.
other than my neighbors either side the next house is over my back fence which would be approximately 50 meters separated by wooded area and a service access road.
Check out the map I linked see if it highlights on there ?
I’m up near Edinburgh this doesn’t seem to cover my area.
Hi Chris, and welcome to GADC we are a friendly bunch of misfits, and Matron will be along a little later with some “light relief”, she is very gentle, but has a thing about Scotsman, so watch out !.LOL
I’ll have a geek for a scottyland variety
Can I just confirm that you are using your username and email?
No password is required and username field is case sensitive.
Hi Callum this has been resolved .
Many thanks
Chris.
Hi… welcome to the group… I’m also Edinburgh and there are a few others around too… happy if there is anything I can help with :grinning: John
Hi John many thanks nice to find some locals to me.
:grin:
