Hi from Alton Hampshire
Hi all, just joined the club, changed after 2 years with a Mavic air to a new mini2 as it’s a lot easier to transport on my ebike and can use in more places than the air. Great kit both of them and being retired have more time to fly. Just fitted a strobon standalone strobe as being 68 the old eyesight is not so good so easier to see.
Welcome to the club @Donb1
Hi @Donb1 and welcome to Grey Arrows :wave:t2:
Have you seen our members map? (Click the burger-menu in the top right) You may find some pilots living near you. Feel free to add yourself to the members map too :+1:t2:
We’re a well established club with many knowledgable members so it’s very likely that any issues you come across will have been discussed here before. Our discussion forum has very powerful search features which should help you find what you need but if you get stuck you can post a new question in the Questions & Answers category.
Looking for recommendations of places to fly? Check out our interactive map on Drone Scene - be sure to log in to gain access to the full suite of features and map layers:
Where To Fly Your Drone in the UK
Find places to fly your Drone (UAV) in the UK and share your favourite flying locations with other hobbyists pilots.
And please feel free to add locations of your own too.
Please also take a moment to look at the Membership Levels section on our FAQ as we’re quite different to other clubs and you’ll be eligible for some rather exclusive club discounts as your membership level increases :blush:
Welcome once again!
Welcome to GADC Don :+1: :+1: :+1:
Unless your add-on strobe weighs less than 1g, are you not exceeding the 250g limit for relaxed flying rules?
The mini2 weighs 240gr, the strobon strobe is only 4gr so well within the under 250 limit. Could even put two strobes on it. :sunglasses::sunglasses:
That’s great to know! I have the first Mini and that is hard up against the 250g limit.
Although I don’t condone flying over the weight limit in reality the chances of you being stopped and your drone weighed by anyone is virtually zero.
If you plough into the back of someone’s noggin and the old bill are called, well, that’s a different story :wink:
If you go over the weight just register as a flyer too as I have, you can then fly in the A1 cat until end of 2022 unless you take the proper test I believe.
