Tapping on the small circle causes the details of the much bigger circle to be displayed.
All of the ‘circles’ are of the same type, so I can’t turn off the other layers, as it turns them all off!
Can you explain how to access a zone that is overlapped by another?
Don’t know how to get that on dronescene, but if it helps you it’s a UAS OPR, NOTAM ID EGGN/C7357/23
Active from Jan 1st 06:00 an until Jan 31st 8:00pm from the surface to 400ft AGL
This does happen occasionally, I don’t know how to get round it. I wonder if it is possible for the people who work computer magic to make the smallest zones display above bigger ones?
We’ve got an excellent solution to this issue and can confirm it’ll be included in the next version update of Drone Scene, along with some other shiny things
Did selecting overlapping zones get fixed? I did a search, and looked through a few DS update notes and the DS About section, but can’t find the solution. Mainly on PC browser for me using a mouse, but would also be useful on phones and tablets.
Great, thanks, I looked at the updates after Feb 24 - too quick! I knew I’d seen it somewhere. I live inside Chalgrove FRZ which has a load of layers to turn on an off, but at least I know how to do it now thanks. Might be worth adding a note about this to the DS About notes.
Just expanding on this query, would it be at all possible to show all of the notices/zones/reports when you click on a location on the map or would that become too unwieldy?
I ask because when I fly in London, there are often a ton of notices piled on top of each other and it would be good to be able to click once and be able to see them all. Otherwise, I worry that one of these days I will miss one of them. In fact, I tend to check Drone Assist (which shows all of the notices when you tap on a location) just to make sure I haven’t missed any of them.
I don’t know if there is any way of perhaps showing them all but grouping them so that people can drill down on the type of overlay they want to see the details of.
I realise I can switch layers on and off and work my way through the overlays that way but, as I mentioned above, I just worry I’ll miss something.
Sorry to follow up on this again but, with Drone Assist’s future unclear, would there be any possibility please of having a way to see ALL of the layers in a particular spot in Drone Scene rather than just those of one layer type (see my previous post above)?
