What I find odd is the fact that it’s not centred on Belfast international airport. It appears to be centred somewhere in the Irish Sea
Approach frequencies can start from 50 miles out from an airport, it doesn’t have to be centered actually on it.
That’s my GIS side coming out
a ‘buffer’ is usually centred on the source point, but as Le60Lad said it appears to be centred on the city airport.
Maybe I’m doing something wrong, but when I zoom out all restrictions disappear ? I wasn’t able to see the full circle so couldn’t work out where the centre was
Really FFS!
Full NOTAM Text
A) EGTT B) 202603301900 (UTC) C) 202603312000 (UTC) E) GNSS(GPS) SIGNAL JAMMING. JAMMERS LOCATED PSN 513010N 0000727W (VICTORIA EMBANKMENT). ACTIVITY MAY AFFECT ACFT WI 10NM SFC TO 34600FT AMSL OR ABOVE (ALL DIRECTIONS). MAY ALSO AFFECT AIRBORNE ELECTRONIC SITUATIONAL AWARENESS DEVICES AND UAS CONTROL. GNSS(GPS) RECEIVERS MAY SUFFER INTERMITTENT / TOTAL FAILURE OR GIVE INCORRECT POSITION INFO. FOR INFO/CEASE JAMMING 07770 444022 OR 07880 503583 AR-2026-2454/03.
Hi, just saw this notam centered on Leeds bradford airport but c 22km radius. I think it might relate to some back up radar system but guess that doesn’t directly affect drone flights. Does anyone know for sure. Thanks.
@JDNT yes, confirmed.
SSR = Secondary Surveillance Radar. Safe for you to ignore that one.
We normally filter out the NOTAMs which aren’t relevant to drone ops.
Will get these added to the exclusion list ![]()
Thanks Pingspike.
@JDNT those SSR NOTAMs have now been excluded from Drone Scene, you won’t see them anymore ![]()
Unless you bought a Shahed-131 or 136 with the fly more combo
Does it come with care & refresh![]()
Blimey… I applied to fly in a Temporary Danger Area and the approval was authorised within 10 minutes!
I’ve whinged a few times about TDA’s and the radius of them, but that’s very good service…
I guess you applied for a date and time? .. or was it just a general “ish” application to confirm on the day?
I gave a specific time and date. I’m not entirely sure if you can confirm on the day?
Did you let “the weather” know your intentions, too? ![]()
I did mention in my request ’ weather permitting '… If it’s called off I’ll try another day. ![]()
