That would be about right!
I didnât know iâd drifted backwards, thought I was going straight back up from where I dropped down, didnât notice that Iâd actually gone through the lines until i played it back at home!
I wonder how much clearance it actually had between the lines, Mavic Pro must be at least 500mm+ from corner propellor tip to opposite?
It looks for all the world like you brought it up until the line popped in to frame, panicked and stopped, then thought âF**k itâ and punched on through!
Basically, I assumed this was your thought process for that split secondâŚ
I was âpunching itâ from lift off!
I think what happened was, with it being a Mavic Pro and not having top sensors, it slowed a touch when the front sensors kicked in, but by then it was too late and it just punched on through!
Woah !
