Just went to log a flight report & there is nothing else going on there, I booked my flight successfully through drone scene but, when I cross referenced it with the altitude angel app it said something like ( not planned, or no authorisation ) so I cancelled it to start again, now every time I try to re log I get this error, It won’t let me re log the same time & location, even tho I’ve cancelled / refreshed it, on the drone scene it told me successfully booked but, on altitude angel as said above, ( meaning the first time I logged it ), I have no log as of now, as stated above.
Kirky, seriously mate, you need to stop deleting everything you create
We can’t help you with anything to do with Altitude Angel, it’s not our app, we can’t and don’t support it.
And we can’t help you with anything that’s been deleted either because, well, it’s been deleted.
Your first screen Drone Scene screen shot, the red banner across the top is telling you that you’re trying to create a new flight report within the same time / date range as one of your existing flight reports. Naturally you can’t fly in two places at the same time.
Your second screen shot which looks to be about 20 minutes later says you have no planned flights booked anywhere at any time.
@PingSpike , ok thankyou for that, the only reason it was deleted ( this time ) as I mentioned, drone scene said it was all good but the actual a angel app said otherwise 100%, or I would have not deleted it for sure, so I thought maybe a glitch.
Nope, hand on heart, that was submitting flight report through drone scene as we discussed the other day,
So I checked the A Angel app as stated above & the report was sat there but basically a no go, so I went back to drone scene & cancelled what was saying all good but showing different on other as said, shortly after an email with my flight plan, which I have here but is obviously cancelled, so I’m confused, I don’t know how to create a flight plan in A Angel either.
Edit : it states created on grey arrows drone scene.
If you create a flight plan with Dronescene you don’t get any acknowledgement via email
The flight plan will be logged in Dronescene and Altitude Angel
If you then use Altitude Angel you can then edit the flight plan
Again I can honestly say, I created all as said above with no mistakes !, I am vey carful when using drone scene as I know what it means to you guys, others that use it too & myself, I would not jeopardise that in anyway, if I was not sure I’d walk away & ask as I did the other day, I appreciate your input @PingSpike & @Sparkyws
Edit : I have tried to contact A Angel which is my hometown telephone number but there’s no reply, probably because it’s a bank holiday.
Hi mate, I don’t want to make this thread any longer than it needs too be,
Everything I’ve outlined is correct to my knowledge but, when I see in the AA app it was basically a no go as compared to what drone scene was saying, I did try to see if it gave me an option within the AA app to see if it showed authorise as per drone scene by way of edit, it would not let me confirm it & I was trying to abide by the rules, otherwise I wouldn’t be having this conversation now,
so with that I thought somethings not right here, altitude Angel supports drone scene or vice a versa, it’s not showing authorised so I had better try & cancel it as I don’t want to risk making a mistake or wandering into FRZ without permission.
