This! ![]()
This! ![]()
Tried that, still no joy unfortunately ![]()
I thinkits something tondobwith settings on my phone. I have also trued downloading dji fly 1.4.2, but after it installs it refuses open…
I’ll just have to stick with the tablet for now. Just wanted to try the phone today as its twice as bright as the tablet
Have you got ‘Install unknown Apps’ enabled?
Did you force close all other apps, did you pay for litchi?
I don’t get that message now (Android 11) but I’ve seen it before when
a) I’ve used the play store on a PC and told it to install an app on my phone
b) When I’m not on wifi but my play store setting is to download only on wifi
Yes
Yes and yes.
I tried the download through my seemingly dumbphone. I am going to switch to desktop site on the browser and see if that works.
I’ve tried on wifi and 5g
In case it helps anyone else I have eventually found the problem. The google play/store apps had auto disabled as they hadnt been used for a while. I have enabled them and set then to NOT auto disable in the future. I now have a dozen apps sitting in a que and downloading.
I’ve recently used Litchi waypoint mission and it wasn’t very smooth. I had the controller set to normal, should I set this to tripod whilst running the mission?
Video here Dorman Long development circuit. 07 08 22 - YouTube
Share the mission and someone will take a look at the settings for you
On litchi hub make sure the mission is not private, then share from there and copy the link to here
And this one
Couple of things
Which drone ?
And no need to be in Tripod, litchi has control so it makes no dfference
Try set your gimbal pitch to interpolate on the waypoints instead of focus POI that should give you a smoother transition
Hi @milkmanchris, I’m using the Air2. I’m not sure if it was an app fault, but thanks for the info about interpolate. I will give it a go next time out.
I also tried with the Air 2 and it wasn’t worth publishing.
must admit I was using the focus poi however, will also try again on interpolate
silly question, and I’m pretty sure I know the answer. I want to fly around a building and take lots of photos to be stitched together and put into kuula or panoee. I’m guessing litchi is going to be the tool for the job?
If so I better dive in as I’m going on Wednesday and wont be able to get back to the site for some time.
When creating actions is there any way of saving or copying them so I don’t have to manualy put them in every waypoint?
