Hi I am keen to know how many seconds long exposure people are getting with their drones before the picture starts to get movement. Obviously wind will play a big part, but say on a windless day what can be achieved.
I have been itching to give it a go but each time I have time to try the weather gods wreck my plans.
I have had decent results up to 2 seconds on the mavic air 2 in pretty stiff breezes, a little less on mini 2. A lot depends on the gusts to be honest. If the wind is steady then generally there isn’t a problem. It’s when you get a big gust blowing out of no place, that tends to F things up.
I’ve had some decent pics at 4 seconds with a Mini 3.
When doing a couple of waterfalls last year I had dent results at 6 secinds using the Air2s with no breeze. All depends if you’ve wind mate🤣
And at 6 seconds was everything sharp ?
The closer stuff in shot was a tad out of focus so either got cropped out or tickled up in post. 4 seconds is better, I done the 6 to see how the water turned out
Yer best bet is to play about an see what you get.
That’s a lovely shot there Ady. Did you just set the exposure, but leave everything else on auto ?
Cheers John.
I generally set to auto on iso and shutter, switch to manual on both then dial the shutter to - 3 on the EV, just to get shut of any overly bright parts. Seems to work
Something I’ll add—which I’m bringing from my handheld photography experience—is to shoot many of the same image and of course only keep the sharpest.
This photo consists of several 3 second photographs stacked to produce the final photo, it was taken with my Mini 2 before I upgraded to the Mini 3 Pro
It was taken at around 1930hrs on a cold October evening and the Mini 2 was fitted with strong ND filter (not sure what ND number was)
Nice one ![]()
Quick question here- I’ve got the mini3 pro, but can’t seem to get more than 2 seconds out of it. Can you tell me how you got longer please?
It can depend on the lighting conditions at the time… I personally take long exposure at night and fly as high as possible to capture a 4 second shot.
You can extend the shutter time by fitting an ND filter. Make sure that you have the ISO set to 100 too.
Thanks. Hope to try today…
