Hi all, does anyone know where I can get a USB that I can use with my Mavic 2 Zoom controller and my HUAWEI MediaPad T3. It needs to be about 20cm long. Thanks
Amazon, eBay, Argos, Curry’s, Tesco, the Esso petrol station on the A19…
The list of places you can’t buy a long USB cable from might be shorter
20cm? Long? Mine is 3m
Skyreat make good cables that work perfectly with DJI , easy to find on Amazon
I think he means to connect his tablet to his controller 3m would be unmanageable lol.
@Zonzie77 just make sure it’s data compatible and not just a charging cable or it won’t work for what you want it for
Almost a competition thread
USB Extension Cable 5M,10M,15M,20M, USB2.0 Active Repeater A Male to A Female Long Cables With Signal Booster (20M) https://www.amazon.co.uk/dp/B07T8F2D3B/ref=cm_sw_r_cp_api_glt_fabc_MTJ09PW280CW7YZZET20?psc=1
Wouldn’t you need a really short one then? Like 6 inches?
Depends how big the tablet is. The cables that come with the drone are designed for phones and are only about 10cm long for a tablet you need it longer so that it reaches from the controller to the port on the tablet as its mounted differently due to its size.
So you need USB-C (if that is what your tablet is to USB-whatevere you controller is.
I bought this for my Tripltek tablet to MA2 controller, £4.50, sent quickly and braided sheath
Hi all, thanks very much for your help Sorrry I probably didn’t explain this very well in the beginning. Yes it’s for a tablet holder so I was thinking about 20cm?? Also the drone comes with a micro type b and micro type a (I think that’s what they are) which is ideal but it’s a bit short. I have tried to Google that specific cord and have gone to Currys but no luck. Unless there is an easier solution? Thanks again
What drone are you using and what tablet?
Me only paying half attention lol doh!
For my M2P remote, which would be the same, I use a USB type A cable n don’t use the mini type connector I find the central one much more reliable, you can source any length from Amazon etc
